Low Vacuum 302
Old Feb 24, 2024 | 08:55 AM
Mjac167's Avatar
Mjac167
Low Vacuum 302
I have a steady (no bouncing or swinging’ low vacuum reading of 10-12 inches on a 302. After checking very thoroughly for external leaks and finding none, I am trying to find out if I have an internal vacuum leak before I pull the manifold. I thought it might be a valve adjustment but was told almost all 302s have pedestal mounted rockers and are not adjustable, you just torque them down to specifications. Can those rockers be so out of torque right now that they are causing problems and any other ideas I can use to narrow down the steady low vacuum to an internal leak around the manifold seal.
Thanks
mjac
Old Feb 24, 2024 | 03:05 PM
wwhite's Avatar
wwhite
What cam is in it?
do a compression test, post the results.
Old Feb 24, 2024 | 06:06 PM
Mjac167's Avatar
Mjac167
It was called a Stage 1 Melling Cam, some people called it an RV Cam.
I was fixing to do a static compression test and even a running compression test but I did not know if it does have an internal vacuum leak from a bad manifold seal if those compression tests would be any good and from what I understand, the compression tests would diagnose a cracked ring, stuck valve or valve not seating or rounded cam lobes. But if I had any of those the vacuum gauge would be wildly bouncing or swinging and my vacuum readings are steady and 10-12 inches.
Thanks
mjac
Mjac167
Mar 1, 2024 10:07 AM
Jermafenser
Aug 29, 2009 07:46 PM
rmalottwtes30
Feb 9, 2007 08:19 PM
LV Dan
Sep 7, 2004 03:17 PM
dan79
Jun 5, 2002 12:48 PM
