Fuel pump failure?
Old Feb 22, 2024 | 07:08 PM
Sparky04SD's Avatar
Sparky04SD
Fuel pump failure?
My '95 F150 4x4 5.8 auto trans seems to be having a fuel pump failure on front tank as it runs perfect on rear tank. Could it be fuel pump. fuel filter or what? 192k miles and both pumps are original. Any ideas how to empty front tank as I just filled both tanks.
Old Feb 22, 2024 | 07:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What kind of fuel pump failure? What is wrong with the front pump? There is only one fuel filter for both tanks so …no. Does the front pump run? Disconnect the hose at the filter run the hose into a gas tank. Jump the EEC self test connector to keep the pump running. Done.
Old Feb 24, 2024 | 11:19 PM
Sparky04SD's Avatar
Sparky04SD
If I start the engine on the rear pump all is good until I switch over to the front pump and then the engine acts like it's running out of fuel. If I try to start engine on front pump it seems to fire on a few cylinders but won't take off. Switch to rear pump and it fires right up immediately.
Old Feb 25, 2024 | 05:12 AM
My4Fordtrucks
Check fuel pressure with a mechanical gauge.
Croskey2010
Aug 6, 2017 04:49 PM
86ford302help
Oct 4, 2013 09:03 PM
Myfreeford
Jul 13, 2011 06:05 PM
kdbbmanton
1997 - 2003 F150
Nov 22, 2005 03:40 PM
lentz321
Mar 17, 2003 05:53 PM
