Soler Performance Throttle Body!
Have you ever wondered what delivers power to your car? It's not just the engine; there is an important part that often goes unnoticed, the Throttle Body.🏁
The Throttle Body is responsible for the critical flow of air into the engine. It propels the car forward when you press the gas pedal. It is key to achieving peak performance and giving your car the breath it needs to come to life.
From idling at a stoplight to hitting the open road, the Throttle Body plays a significant role in your driving experience. It's a subtle yet essential component that ensures your vehicle performs at its best. At Soler Performance, our professional engineers handle each part to provide superior performance, durability, quality, value, and extensive research and tests to ensure you get the best Throttle Body on the market. Our products outperform and have consistently better quality than anything else on the market. Don't take our word for it, try it for yourself or read our hundreds of 5-star reviews.
With an upgraded Soler Performance Throttle Body, you will also experience a lower weight-to-power ratio at part throttle, making your driving experience more nimble and sprinted. You will also experience crisper shifts, immediate response right off idling while keeping the idle function undisturbed, no requirement for tuning, more air/power at every single throttle position after idle, and easy installation.
So, the next time you're on the road, take a moment to appreciate the Throttle Body, the part that makes your journeys smooth and exhilarating. Visit our website for more information and don’t forget to use discount code: LL5%OFF at checkout! 🚀💨
Soler Performance LLC (solerengineering.com)
SOLER | PERFORMANCE (@solerperformance) • Instagram photos and videos
mzbrooks@solerengineering.com
McAllister Brooks
Sales & Marketing Manager
Use discount code LL5%OFF at checkout!
McAllister Brooks
First, any airflow that does not result in higher total airflow >at wide open< is not an advantage at lesser throttle openings. Was this found in Airflow Bench testing?
Secondly, most throttle bodies are so far from the cylinder port runners that any so called mixing or air motion is lost, over that distance and direction changes plus the presence of port flap air control (IMRC)
Third, what "mixing"? Its all air at that point.
Forth, The Ox Sensors do the fuel control according to the Ox level detected in the exhaust. TB can't change the fuel tables directly. On late Ford after 2010, the Ox Sensors do the A/F Ratio detection right at the sensors and send that result to the PCM direct for much faster fuel corrections.
Fifth, the Throttle angle Sensor advancement could be part of throttle response enhancement. Hard tell on any given engine unless tried and proven.
The >rate< of throttle opening detection is what usually adds fuel for fast accelerations. Throttle modifiers do this. On stock Fords there is already throttle modification built into some of the shift modes. ECO, Manual, Wet/Snow etc.
They sure to look pretty, otherwise.
Good luck.
At partial throttle, more airflow makes the engine respond faster, the vehicle feels nimbler during transient maneuvers which are very common at partial throttle. In a steady state, your comment is correct.
The extra airflow is detected by the MAF sensor and the corresponding extra fuel gets added by the ECM (per table), the oxygen sensors control the fuel trims, a small correction to balance whatever the MAF might have missed.
We do not change the throttle body intrinsic calibration, there's no such feature as "angle advancement" in our throttle bodies. Maybe we misunderstood your comment.
Thanks!
McAllister Brooks
McAllister Brooks
The system is Speed Density based.
A MAP-T Sensor projected into the Intake is a large part of fuel control that has to respond to throttle opening changes in the same space.
by intake vacuum level changes, not mass air metering changes.
Fuel main control is a power controlled fuel pump capacity variation.
2018 and later, 5 L engines have dual fuel injection. That is both direct in Cylinder and Port injection.
This injection is a complex control of the two by percentages at the same time depending on engine temperature, RPM and load.
This control results in multiple injector tables for that much control resolution.
Also the separate injection systems runs at greatly different pressures between the two.
Low pressure port at about 70 psi +/-.
High pressure at as much as 3000 Psi is a separate mechanical pump fed from the low pressure system and boosted and with internal bypass pressure control.
V6 Turbo charging is somewhat a different animal for control under Boost where the intake works across a Vacuum to zero then to positive intake pressures..
It has to be seamless in dynamic operation over this extreme range as well as control variable valve timing of both intake and exhaust camshafts over the rpm band..
In any case, they will work equally well on speed-density tunes, as long as the engine can estimate the increased airflow. Also, most folks doing this are going to be tuning anyway.
If the TB becomes the bottleneck, we are here, we have all sizes from 80 to 103mm, all kinds of adapters, and we also do custom work/matching.
McAllister Brooks
2015 up F150 are MAP sensor systems on GEN 1 and 2.
Mine is 2018 5L Gen 3. Heads flow more air, intake Manifold flows more, CR 12 to 1, Cam timing a bit more, and Revs will go higher into 7 k, just stock, as a result.
When there is a 'need' for those big 'holes' , usually injectors sizes have to be increased as well as fuel pump volume to feed a hungrey animal like high boost pressure. applications. Ford Motor Sports as this hardware, now.
Thanks.
McAllister Brooks
