‘24 Lariat HUD Reflection?
Old Feb 20, 2024 | 05:42 AM
dseg's Avatar
dseg
Does anyone else see a reflective rim at the bottom of the HUD? If I sit low or adjust the height of the HUD I can make it disappear but if I’m high, I can see edge of the glass where the HUD reflects. I’m thinking i can get rid of it if I just put a trim peice at the end of the glass but was wondering if this is normal.
Old Feb 20, 2024 | 07:10 AM
Fox-BLUE1's Avatar
Fox-BLUE1
I’ve been driving with mine for almost a year now and haven’t noticed anything like that. Have you tried adjusting the vertical position from the HUD menu?
Edit: I see you already tried adjusting the vertical position. Not sure I’ve seen that slim reflection at the bottom of your pic on my HUD.
Old Feb 20, 2024 | 07:16 AM
dseg's Avatar
dseg
After looking at some YouTube videos, it may be normal. Here’s an example, if you look at the 15 second mark, there is a reflection line at the bottom. If you don’t see it, try raising yourself up, if you sit low you can’t see it though.
you can also see it at the 45 sec time, you just need to sit up to see it I think.
Old Feb 20, 2024 | 06:20 PM
dseg's Avatar
dseg
Anyone else able to confirm this?
Old Feb 20, 2024 | 09:00 PM
supeRobertduty's Avatar
supeRobertduty
More technology, equal more problems. I remember when trucks used to be trucks.
Old Feb 20, 2024 | 10:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Maybe it's just because you were high.
Lots of strange visions can happen when you're high...
Old Feb 20, 2024 | 10:23 PM
kry226's Avatar
kry226
Never noticed on my 23.
Old Feb 21, 2024 | 07:24 AM
Fox-BLUE1's Avatar
Fox-BLUE1
Just went out to the truck to look again. If I sit low or high, I don’t see it. If I go forward I can see a small reflection at the bottom. The photo below is when I was near the steering wheel and I can see the reflection on the bottom. I have to be pretty far forward to see it though. I’ve never noticed it over the last year since where I sit it’s not in my FOV.
Seems to be normal to me. Might just have to adjust your seat so you’re not seeing it while driving.
PLM1955
49
Sep 20, 2022 07:16 PM
dstraw
Oct 11, 2017 02:17 PM
Fordking1978
Aug 30, 2017 03:01 PM
BarnieTrk
Sep 14, 2015 07:58 PM
acf6
Feb 16, 2013 05:56 PM
