Tailgate patch panel
Old Feb 20, 2024 | 01:14 AM
66shortbed's Avatar
66shortbed
Hi all,
Recently sold my 69 3/4 ton for a much more solid 70 1/2 ton. Unfortunately, somewhere along the way, someone mounted reflectors to the bottom of the tailgate, leaving 2 reflector sized rust holes. I have (2) 6" sections to repair. The repair goes just a little above the bend I am trying to find a patch panel for the lower section of the tailgate. It seems like this is a common place for rust but I keep coming up empty on a pre bent repair panel. Anyone know where I can get one?
Thanks
Old Feb 20, 2024 | 06:06 PM
LACzar's Avatar
LACzar
Something like this...https://www.ebay.com/itm/27205818620...0AAOSwSeNlwVk3 _ Tony.
Old Feb 21, 2024 | 12:59 AM
66shortbed's Avatar
66shortbed
Thank you LACzar. Something like that indeed. However, because I need about 1/32 of that panel, I was hoping to find something a little less expensive. With shipping, that piece would get me to more than half the cost of a repop tailgate.
Does anyone know if the profile of the early Broncos tailgate is the same as our trucks?
There are a couple different folks offering a piece almost exactly like what I need, but for classic Broncos. Like this one:
https://tomsoffroad.com/parts/66-77-...r-repair-panel
Old Feb 24, 2024 | 04:49 PM
RTT's Avatar
RTT
Red face
Someone posted a co. like tamco .............I can not remember...........they sold several panels , rocker , floor etc.......... , check out rocker arm or floor pan post...........I may look for u later if needed..........
Old Feb 26, 2024 | 11:13 PM
66shortbed's Avatar
66shortbed
FWIW:
The early bronco tailgate is the same profile (at least at the bottom) as our bump side tailgates. Obviously the patch panels aren't long enough to replace the whole bottom section of a full-size tailgate, but if you have a couple holes, like I do, these bronco panels are great. Jeff's Bronco Graveyard seems to have the best price.
Binkowski
Dec 2, 2016 10:22 AM
1997fordf350
May 9, 2013 06:45 PM
carriljc
1978 - 1996 Big Bronco
Mar 18, 2013 02:29 PM
SHOpar
19
Nov 6, 2009 02:02 AM
1991_BigBoy
Dec 3, 2002 11:02 PM
