1978 - 1996 Big Bronco
Lower Tailgate Patch Panel
Old Dec 25, 2012 | 10:08 PM
carriljc's Avatar
carriljc
Need to repair my tailgate lower edge. It's rusting a bit badly.
I thought JCWhitney used to sell patch panels but I can't seem locate any.
Anybody have any leads or pointers?
EDITED:
Nevermind. I found a patch panel at lmctruck.com
Old Dec 26, 2012 | 12:40 AM
greystreak92's Avatar
greystreak92
Replacing just the lower portion of the gate is not exactly advisible as the rust along the lower portion of the gate begins on the inside and comes out. The outer skin of the gate is not the only area compromised when this happens. The inner wall of the gate where it is seamed and folded in with the outer sheet metal will be compromised as well and a patch panel will suffer the same fate as the original outer skin if not supproted by the inner gate metal or if resting against the rusty remnants of it.
This is not to say that folks haven't repaired just the outer sheet metal but its rare that its the only problem if the area has rusted through or shows signs of bubbling paint.
Old Dec 26, 2012 | 10:05 AM
carriljc's Avatar
carriljc
Thanks - I can patch the rest...
....with some sheetmetal. But I'm not exactly artistic so I thought it'd be better if I bought a professionl piece for the outside.
I don't understand why Ford put that goofy seam at the bottom of the tailgate. It's a horrible rust trap.
If I could buy a U-shaped bottom, I'd just do that......but otherwise, I can work around that.
Old Jan 2, 2013 | 11:58 PM
carriljc's Avatar
carriljc
Smile Received my tailgate patch panel today...
...from lmctruck.com today.
I took some pictures of it but don't know how to attach them.
I has a little "lip" at the bottom and on each side. It is approximately 67 1/16" wide and 9 2/8" tall. (I state that because I was curious about it myself).
It is part number 49-8334 in the link below.
The part is labeled as being for a 1980-86 but the book below says it'll work for my 1990. Some research on different websites also indicates that it should fit my 1990.
The sticker label states that it is 1mm gauge thickness.
Truck Parts and Truck Accessories
Old Mar 18, 2013 | 02:29 PM
mweeps's Avatar
mweeps
Does anyone know why it only goes to 93? Did somehting change in 94 to tailgate?
fabieber
17
Nov 7, 2012 09:46 PM
SHOpar
19
Nov 6, 2009 02:02 AM
blue beast
Nov 17, 2007 02:20 PM
Superman_ManOfSteel
Apr 14, 2004 12:04 AM
1991_BigBoy
Dec 3, 2002 11:02 PM
