DANA 60 UPGRADE
Old Feb 19, 2024 | 04:57 PM
Rad082625's Avatar
Rad082625
DANA 60 UPGRADE
The Dana 60 in my 1962 F250 4x4 is too old for any lockers or limited slips due to the spline count. So what should I look for in a later year Dana 60 for a bolt in swap?.....Bob
Old Feb 19, 2024 | 09:11 PM
PROSTOCK's Avatar
PROSTOCK
Whatever you find now that is "bolt in", is going to be problematic. Finding one better than yours may be fruitless. Good luck.
If you have a welder, grinder, gumption, and a little skill to go with that, get a later model Dana 60. It requires you to move spring perches in along with shock mounts to match your frame rail width, all while maintaining pinion angle. Very doable. I have one from an '81 in my '65 and it's great. Those were used forever and parts are easy to get.
Old Feb 19, 2024 | 09:29 PM
Rad082625's Avatar
Rad082625
According to others including Numbers Dummy bolt in versions are out there, I just don't know which years. 73-77 f250 are supposedly the same as 61-72. And then 73-77 f100 4x4 Dana 60s bolt in . I'm just looking for further confirmation. Right now the truck is waist high in snow but I know I need to crawl under and measure brake backing plate and spring pad width. Just trying to get a jump on things to minimize wild goose chases...Bob
Old Feb 19, 2024 | 10:22 PM
52 Merc's Avatar
52 Merc
Axle and spring perch width are the same up through 72 and will bolt in. In 73, the frames got wider (4") to make room for inboard gas tanks which set the spring perches out farther. I believe the axles themselves are an inch or two wider, as well. The newer axles can be used but will require cutting and welding of the spring pads to fit. No need to go laying in the snow for this.
Old Feb 19, 2024 | 10:48 PM
Rad082625's Avatar
Rad082625
Smile
Thanks Wayne but hey, maybe I like laying in the snow. you never know
Old Feb 20, 2024 | 08:44 PM
PROSTOCK's Avatar
PROSTOCK
The wheel mount hub to hub is slightly wider. I used the same wheels and tire before and after; 265/75-16 are as big as I think you can go and they fit perfect..
What it does best.
Easily 500lbs of steel leftover in it from shop build
Old Feb 21, 2024 | 08:20 AM
Rad082625's Avatar
Rad082625
So with the info so far, I have a line on a 67 f250 CS Dana 60, and it should bolt in, right?....Bob
Old Feb 21, 2024 | 09:15 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I think it will bolt in fine, but you'll have to figure out what to use for rear brake cables. I doubt the 1962 cables will work with the 1967 backing plates, etc. Might get lucky.
Old Feb 21, 2024 | 09:10 PM
FarmMotorSports's Avatar
FarmMotorSports
Food for thought. I reused my 1961 e brake cables on my 89 Dana 61... They work just fine. Don't fit perfectly some bends are tighter than I like.
Old Feb 22, 2024 | 07:37 AM
Rad082625's Avatar
Rad082625
Thanks for that....Bob
Old Feb 24, 2024 | 09:00 AM
BarnieTrk's Avatar
BarnieTrk
IIRC, the '67 axle would have wider brake drums and shoes than the '61.....
BarnieTrk
Casey Hope
Offroad & 4x4
Apr 8, 2018 10:29 PM
capo88
May 6, 2003 08:30 PM
