4 speed automatic
Old Nov 24, 2003 | 04:09 PM
jwyatt's Avatar
jwyatt
4 speed automatic
are there any 4 speed automatic transmissions that will bolt up to a 351m/400? and is there a way to convert a 351m/400 from a 2 bolt main to a 4 bolt main?
Old Nov 24, 2003 | 04:46 PM
Bill_Beyer's Avatar
Bill_Beyer
Any transmission that will bolt up to a 460 will bolt up to a 351M/400. For specific models you might want to check in the Transmission forum.
There are no factory or aftermarket 4 bolt main caps made for the 351M/400 that I'm aware of like there are for the 351C. Could you hire a machinist to make some and modify the block? Probably.
Old Nov 24, 2003 | 10:43 PM
Brian S's Avatar
Brian S
4 bolt caps or stud girdle
They aren't advertised but I was told you could special order 351M/400 4 bolt caps from Pro Gram for slightly more than the 351C caps.
http://pro-gram.com/catalog/catalog.cgi
The caps are already pretty stout, you won't gain much with 4 bolt caps, Chevy motors are a different story.
Much more reasonably priced are the stud girdles from FPS.
http://www.f-p-s.com/
fair67driver
Large Truck
Jul 22, 2022 04:58 PM
derherr65
19
Aug 23, 2019 06:29 PM
79-F350
May 3, 2014 12:23 PM
blacklabel21
Jan 5, 2011 10:22 PM
fordguy76
Jan 20, 2002 09:03 AM
