Sponsored by: Real Truck
6.2 F250 occasional misfire
Old Feb 16, 2024 | 04:11 PM
charliekawi's Avatar
charliekawi
3rd Gear
I have a 6.2 F250 and there is a misfire/popping noise coming through the intake. I’ve attached a YouTube video with the noise for a better understanding.
I don’t know what could possibly be causing this popping noise coming through the intake, I believe it’s a misfire on one of the cylinders, but I’m not getting any CEL‘s or trouble codes. I’ve already replaced all 16 plugs, 8 plug wires, and 8 coil packs and the issue is still here. I was thinking it might be a bad injector, but I’ve unplugged all the injectors, 1-by-1, and while each one was unplugged, I heard the popping noise at least a few times. Has anyone had a similar issue or have any idea what I should check next? Thanks in advance. YouTube video of misfire/popping sound:
–Charlie.
Old Feb 17, 2024 | 10:03 PM
WWR's Avatar
WWR
Any pending codes??
What about misfire counts? NOT codes, the actual counts in Mode 6/Onboard Monitoring??
If you can get any of that you have an idea of where to focus.
You might look at valve springs. Try a leakdown if you can get any misfire counts
Old Feb 21, 2024 | 06:43 PM
YourMom's Avatar
YourMom
6th Gear
2nd that valve spring, i think #5 is common on pass side.
Old Feb 21, 2024 | 06:52 PM
JDHog's Avatar
JDHog
1st Gear
Misfire noise
https://youtube.com/shorts/KYb9sGSTk...aYS60JJeWmbZSM
I don’t know what could possibly be causing this popping noise coming through the intake, I believe it’s a misfire on one of the cylinders, but I’m not getting any CEL‘s or trouble codes. I’ve already replaced all 16 plugs, 8 plug wires, and 8 coil packs and the issue is still here. I was thinking it might be a bad injector, but I’ve unplugged all the injectors, 1-by-1, and while each one was unplugged, I heard the popping noise at least a few times. Has anyone had a similar issue or have any idea what I should check next? Thanks in advance. YouTube video of misfire/popping sound:https://youtube.com/shorts/KYb9sGSTk...aYS60JJeWmbZSM –Charlie.
Im having the same Issue with my dads f250, sounds like its coming from the throttle body. Seen another guy swap out the evap purge valve, so Im trying that first. Anyone else find a solution? Truck hesitates pretty bad under acceleration but same noise as in your vid
jswartz84
Jun 11, 2022 02:43 AM
itguysc
Sep 25, 2020 06:18 PM
lhickey212
Oct 5, 2016 10:14 PM
rbizzell36
May 11, 2013 12:18 PM
sjwoody
Jul 25, 2005 05:30 AM
