F600 wheel end help
Old Feb 16, 2024 | 02:33 PM
servicetrucker's Avatar
servicetrucker
Trailering
F600 wheel end help
I need everything to do brakes, seals, cylinders, and wheel bearings on the rear of my 1970something F600. The only thing I know is it has 6 hole budd wheels and is a 15k eaton. I remember the brakes are the same diameter as the front but wider from when I got front brake shoes from napa and now I can’t find them. The people at a supplier here said take it apart and come back with the parts so we can match it up but I use this truck pretty regularly and don’t want it to be down for long. There’s no numbers on the banjo housing I can see but there is these on the hoghead (picture). I posted in the large truck section yesterday but didn’t get anything yet. Thanks in advance
Old Feb 16, 2024 | 03:52 PM
440 sixpack's Avatar
440 sixpack
I have a fleet of this type of truck and even when they were newer you almost had to take the part down to the truck part place and match it , or at least get the numbers off the parts. I don't believe a good set of books ever existed and they almost certainly don't anymore. it's irritating but that's just the way it is.
Old Feb 16, 2024 | 04:24 PM
servicetrucker
Trailering
I’ll just have to pick a time I don’t think I need the truck then. Ugh
Old Feb 25, 2024 | 07:57 PM
servicetrucker
Trailering
I posted this in my other thread and I’ll put it here to so it’s more likely to be found
I tore into it and what I found was
15x5 brakes napa# ft-400-r shoes
wheel cylinders napa# 37149
wheel seals national# 370047a
outer wheel bearing 3982
outer race 3920
inner wheel bearing 33287
inner race 33462
servicetrucker
Large Truck
Mar 3, 2024 01:12 AM
Djstright
May 30, 2016 05:36 PM
GaryKip
13
May 24, 2016 03:49 AM
Pbbbfischer
Jul 18, 2015 07:49 PM
OGB
Nov 4, 2010 12:06 PM
