6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Driver side battery cables
Old Feb 16, 2024 | 11:25 AM
Karma89's Avatar
Karma89
1st Gear
I have an 08 6.4 and as far as I can tell, there are only 2 cables that hook up to the positive terminal on the driver side battery. 1 cable connects to the passenger side battery but I can’t figure out where the other cable goes, and I can’t follow it cause it’s routed underneath the fuse box and then vanishes. This cable is draining my batteries, it gets red hot when I try to crank the truck. Any suggestions?
Old Feb 16, 2024 | 06:58 PM
DieselDenny's Avatar
DieselDenny
Take this as you will, but you need to chase that wire. Plenty of diagrams out there.
There are two leads to the battery. Your main concern should be voltage spikes to the ECM which will roast the truck.
Cut the looms for the cable, wiggle and follow. Don't be lazy.
You need to replace that unit or you suffa.
Denny
HitmanViper
Apr 18, 2023 05:05 PM
BigBlue2
Sep 26, 2022 10:07 PM
scottymacc
Apr 11, 2021 03:40 PM
h.ubk
Oct 7, 2019 08:21 PM
mono570
Oct 14, 2018 07:58 AM
