Stock Wheel Width
Old Feb 15, 2024 | 07:15 PM
jbwardfamily's Avatar
jbwardfamily
Stock Wheel Width
Hi all. Just picked up a new '24 F250 XLT with 18 inch wheels. Any idea of the wheel width? Not something that was on the window sticker and I want to upgrade to 35s next week.
Old Feb 15, 2024 | 07:19 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Most likely 8". If you go to a 35x12.5x18 you will likely need at least an 8.5" wheel for some places like Discount Tire to install them. However, you can also just order/buy them from anywhere and take them to a local mom and pop shop and they will most likely install them for you.
Edit to add: You can get a 285/75/18 and that will get you a 35" tire, but it won't be quite as wide. it will install on an 8" wheel though. I just put 295/70/18's on my stock 18" wheel and I like them a lot. They fill out the wheel much better than the stock Wranglers, and they look better on the truck. These measure out to a 34.3x11.6x18, so not quite a 35" but it's close. Plus, they were quite a bit less expensive than the listed 35x12.5x18 tire too!
Adding some photos. The width of the 295's look really good, but I can't get a good picture of it... Also to note, these are the Falken Wildpeak AT4's, which are wider than some other tires in the same size.
Side shot.
Here's a shot showing how much they poke out... The Weathertec mudflaps are the perfect width to stop water/debris from getting thrown into the truck.
Old Feb 15, 2024 | 07:33 PM
Rwhjr's Avatar
Rwhjr
Yeah I did similar to what is posted above.
instead of going with the 35x12.50 I went with 295/65r20.
I know you have the 18s but it’s a similar thought process that I didn’t want the 12.50 tire on the 8” wheel. I’ve done it before and it wasn’t a safety issue but it does look kind of bulged out and I had a little harder time getting the air pressure right for tire wear.
My 295s are actually a hair taller than the 35x12.50 but about an inch less wide. I think they look great and a 295 on a stock 18 would look nice too.
Old Feb 15, 2024 | 09:19 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Wheel size is cast into the back side of the wheel.
Old Feb 15, 2024 | 11:53 PM
Joe T's Avatar
Joe T
Its an 8”.
305/70/18 is what you want. Bit taller and a little skinnier than a 35x12.50 but works on an 8 inch.
You can run that stock lift, put your money into high quality shocks.
Not going to help your towing but you can lock into 9th.
Post pics Not a common size.
Old Feb 16, 2024 | 12:21 AM
mwheue's Avatar
mwheue
Stock wheel width is on white sticker in drivers door jamb.
Old Feb 16, 2024 | 05:55 AM
Poncho450's Avatar
Poncho450
As chadstick mentioned above, make sure your tire seller will mount the tires for you. I once bought and paid for a set of Falken Wildpeaks online from Walmart. To be installed at one of their local stores. 30 minutes after I dropped the truck off and left they called me. Against company policy to install tires a certain size above what is on the door decal. Got the money refunded to the card and exited with the truck.
Drove directly to a local branch of a regional chain and ordered the same tires. Actually a few dollars cheaper and they had no problem installing them.
Old Feb 16, 2024 | 07:55 AM
roguewave's Avatar
roguewave
Busted Knuckles
I’m trying to get as tall as possible while keeping stock rims. Looks like 35/11.50/18 is it ?
Old Feb 16, 2024 | 08:20 AM
Joe T's Avatar
Joe T
That load rating won’t work on those.
305/70/18 or 285/75/18 or 315/70/18.
Old Feb 16, 2024 | 08:28 AM
chadstickpoindexter
The 275/75/18 in the WP AT4’s is listed as a true 35” tire, but it isn’t super wide.
Old Feb 16, 2024 | 08:29 AM
T. Banning's Avatar
T. Banning
Here’s another photo of 295’s on stock 18” wheels.
Old Feb 16, 2024 | 08:36 AM
WXboy's Avatar
WXboy
If you want a so called "true" 35" tire, you'll want to buy something that is listed well above 35" in the manufacturer's data. Fast forward to 12:45 or so in this video for some more discussion on that:
Old Feb 16, 2024 | 08:43 AM
Poncho450's Avatar
Poncho450
I've always used this site as a reference: https://tiresize.com/height-chart/
Old Feb 16, 2024 | 09:38 AM
RandyinTN's Avatar
RandyinTN
What engine and gear ratio?
Old Feb 16, 2024 | 09:43 AM
Joe T's Avatar
Joe T
He posted in another thread its a 7.3/3.73 and he plans to pull a 12k 5th wheel eventually.
