1988 e350 smog pump delete
Old Feb 12, 2024 | 10:40 PM
Finlan-2005's Avatar
Finlan-2005
I plan on removing the smog pump on my motorhome. It has a 460 v8 in it and I’m just wondering what kind of work goes into this and if anyone knows a belt I can use once it is removed.
what hoses will I have to remove? The steel tube going to the cat has already rotted off so that’s already dealt with, are there any other hoses that need to be removed?
also will there be any vacuum lines that will need to be capped off? Any vacuum canisters I could remove along with it?
finally are there any issues this could cause with how the engine runs? Will it throw a code? It is OBD1 so I don’t think it will but I just want to be sure
Old Feb 13, 2024 | 03:36 PM
econo93's Avatar
econo93
Can't help you with the specifics on a 460 but I deleted the pump on my '93 w/351 and it threw no codes.
You will read opinions about the CAT clogging up eventually but it's been a year and 7000 miles on mine and that hasn't happened yet.
Getting the right length belt was a little tricky since there are different ways to go with the idler and/or tensioner (on a 351 anyway).
Poke around a bit and you'd probably find some good info on a 460:
https://www.google.com/search?client...og+pump+delete
Old Feb 13, 2024 | 09:15 PM
Finlan-2005
I’m definitely deleting the cat too, it is very rotted out and all my local auto parts stores have new ones listed at around the $2000 CAD range which is ridiculous. My buddies and I bought the motorhome about two weeks ago and we recently found that the previous owner tried to fix it with RTV silicone😂
thanks for the info, I’ve found a few different belts that will probably work
Old Feb 21, 2024 | 12:16 AM
maples01's Avatar
maples01
How's the 460 sit in there, room? I'm tired of trying to get the stupid 4.9 to run right, mechanic has a Lincoln with a 460, gonna see if he'll put it in my van, should be fun in a shorty.
Plug your vacuum lines, keep the EGR, you'll not have any codes, mine wasn't affected, capped the pipes in the head.
Old Feb 24, 2024 | 05:39 PM
Finlan-2005
The 460 is really shoehorned in there, not a lot of room to do much of anything. I am dreading the time I have to replace the spark plugs. It has plenty of power, but the engine bay is really cramped
hillm250
Mar 4, 2019 10:47 PM
FordYoungGun35
Aug 20, 2012 07:24 AM
roadrash63
Jun 14, 2009 07:00 AM
fomocojake1
Jul 10, 2007 06:37 PM
mstaser
Apr 6, 2003 11:39 PM
