My alignment saga, help needed
Old Feb 12, 2024 | 09:39 PM
Summers22's Avatar
Summers22
Originally Posted by willynilly
it meens its pushing the draglink making it steer left
I know that part, what's the fix? I need a stabilizer......
Old Feb 13, 2024 | 08:12 AM
kylant's Avatar
kylant
post up your specs from yesterday.
try removing the bilstein steering stabilizer. they are gas charged and could possibly cause the left pull
does your truck have the adaptive steering?
did i mention the issue on my '20 that had a right pull with perfect alignment?
Old Feb 13, 2024 | 08:17 AM
Summers22's Avatar
Summers22
They don't print out specs, or at least they didn't yesterday. No adaptive steering, it's normal 2019 XLT 603A. They are trying for .10-.15 toe in on both sides today when I go back.
Old Feb 13, 2024 | 08:19 AM
kylant's Avatar
kylant
gotcha. no adaptive steering eliminates what caused my pull
Summers22's Avatar
Summers22
What's a good steering stabilizer that won't cause pull and doesn't break the bank?
Old Feb 13, 2024 | 08:25 AM
user 474747383's Avatar
user 474747383
***** is right I put my stock one back on and solved my slight pull to the left.
Old Feb 13, 2024 | 08:27 AM
Summers22's Avatar
Summers22
Okay, that would mean buying a stock one, which is fine. I see some advertised as "neutral pull" or something to that effect.
Old Feb 13, 2024 | 08:33 AM
user 474747383
My stock one is fine.
Old Feb 13, 2024 | 08:35 AM
user 474747383
Current Measurements,,, I would had set the tow on this and let it go.
Old Feb 13, 2024 | 08:38 AM
Summers22's Avatar
Summers22
They tried setting the toe to .0 yesterday and it made no difference, actually made it worse, so trying for .10-.15 each side today. I only threw on Bilstein SS because the stock one had 120k.... Should have maybe just went with stock.
Old Feb 13, 2024 | 08:42 AM
user 474747383
I set my tow a 0.06 matched
Old Feb 13, 2024 | 09:39 AM
4wd6.7L's Avatar
4wd6.7L
Adaptive steering caused pull on yours? How so, you replaced the steering wheel to determine that?
Old Feb 13, 2024 | 09:41 AM
  #28
4wd6.7L's Avatar
4wd6.7L
I have the Bilstein stabilizer and no left (or right) pull. You could probably get someone to give you their stock one for free though.
Old Feb 13, 2024 | 09:43 AM
  #29
Summers22's Avatar
Summers22
When I first installed the Bilstein, there was no adverse effect on pull, so I doubt that's it. We will see what they say today at the shop. I may just end up buying a at home toe tool kit and figure it out myself.
Old Feb 13, 2024 | 10:02 AM
  #30
kylant's Avatar
kylant
ya, it was something within the electronic steering system that was causing my pull. i started pulling all the fuses related to steering. one of them (don't remember which) seemed to "reset" the system. I had all kids of fault lights on when it was pulled, but the truck drove straight. i reinstalled the fuse, all the lights went off, and the truck continued to drive straight.
i had been chasing my tail with the alignment. multiple different caster shims, toe setting, etc...
didn't change or do anything with the steering wheel
