FORSCAN engineer/developer
Old Feb 12, 2024 | 09:36 AM
Tony Hooton's Avatar
Tony Hooton
8th Gear
Happy Monday! Hope everyone had a good weekend. I would like to speak with a FORSCAN engineer/developer regarding 23+ Super Duty. Looking to increase the tire diameter parameters to 3280 mm and 3430 mm so the trucks don't throw drive assist alarms. At min, increase to 3280 mm, but would be nice to also have the 3430mm option. Right now the max increase is 2780mm. Truck in picture is equipped with a hypertech tuner.
PFA
Old Feb 12, 2024 | 10:58 AM
djousma's Avatar
djousma
That Truck in the picture is not a 2023+ model, just looking at the vent on the front fender, and no step pad on the box.
Old Feb 12, 2024 | 11:05 AM
Tony Hooton
8th Gear
That is correct. But the question is still relevant, and it is PFA as these tires are 3280 mm tall.
Old Feb 12, 2024 | 12:15 PM
Poncho450's Avatar
Poncho450
I think they're Russian. Good luck. Your bets bets around here are ZooDad or Livinitup.
Old Feb 12, 2024 | 12:26 PM
JoeUser's Avatar
JoeUser
Your best bet is to peruse the forum on their site, perhaps. https://forscan.org/forum/
Old Feb 12, 2024 | 09:56 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
ForScan can only change what is programmed in from Ford code.
Currently Ford code only allows 2770
Beat bet is aftermarket at this point in time.
ZooDad
Old Feb 13, 2024 | 10:36 AM
WE3ZS's Avatar
WE3ZS
ZooDad
I’m not a Forscan user (yet….) but I think I recall some conversations in the EX forum regarding taller tires than the PCM could accept, with the Sterling 10.5” rear axle with the ring gear tone ring some folks had success altering the number of “teeth” on the tone ring within Forscan to trick the PCM into thinking less revs to offset the bigger tires. Requires some math of course to get to the desired target. Not sure how the modern trucks are setup for a VSS (tone ring still?) and if this work around would be possible. I can try to find the thread(s) in the big wagon section to hopefully explain it better.
Old Feb 13, 2024 | 08:44 PM
ZooDad's Avatar
ZooDad
That procedure used to work. No longer with newer trucks.
ZooDad
Old Feb 13, 2024 | 08:58 PM
Joe T's Avatar
Joe T
Does changing the gearing programming work?
I put a 3.73 in my 2016 F150 (changed from 3.31) and the speedometer was off.
Old Feb 14, 2024 | 06:46 AM
Poncho450's Avatar
Poncho450
As ZooDad mentions there are aftermarket calibrators from Hypertech and others. Sounds like it may be the only option if it's outside of FORScan's parameters.
But it may be an expensive solution for a one off use.
F2shiitty
Feb 3, 2024 10:26 AM
sunbelt57
Offroad & 4x4
Oct 21, 2019 08:53 AM
UGA33
Mar 4, 2017 01:43 PM
F350-6
30
Apr 15, 2012 08:56 PM
5.4L to Freedom
Nov 5, 2008 01:58 PM
