Another rear axle ratio question
What I have: 51 F1, engine will be the flathead slightly bored and pretty well stock innards, holley 390 4 bbl to breath, Mallory dual point distributor and offy finned heads, compression about stock or slightly increased. Trans will be stock 3 speed. Tires will be the 235/75/15.
What I want: To be able to drive on the highway at 65 without getting run over or screaming the motor, but able to take off on a hill without burning the clutch out. This will NOT be a work truck, but I do plan on driving it a lot, long trips included.
The axle I got has 3.7 gears, and look pretty worn. I am thinking 3.25 gears will be my best bet for all around driving. Have any of you got something close to this set up and what are your suggestions? Also, if I go to 3.25, should I consider the 11" clutch as well?
When you're ready to get rid of the 3.70 ring and pinion, let me know. I'm going back to a stick shift in my truck, and need to get some 3.70s again.
What's the back lash on them? If it's still around .010" I could prob use them. If you find the gears you're after, I'll take the old ones.
Let me know....
The HD unit has a first gear ratio of 3.71:1
Standard unit first gear ratio is 2.78:1
I have a 9" with 3.50 rear gears and I run the flathead at about 62-65 mph without strain. That works out to about 2400 rpms. With my HD tranny ratios I could even go with 3.25's. If you've got a standard tranny, 3.25's might be pushing it a bit.
Sixoh, sorry, but I think these 3.70s have lived their life. I haven't measured backlash but can see a lip worn onto each tooth, pretty well used up I think. The junkyard I got the axle at had the truck up on a forklift, torched off the u bolts to get the axle off, then took the truck over and dumped it over on its side on a hill. Pretty well summed up the gear condition!
John in Sacramento
