Correct U-Joint size
Old Feb 10, 2024 | 03:33 PM
NW 150's Avatar
NW 150
What is the correct u-joint for the front driveshaft on a 1996 f150 4x4 with the manual transmission? I ordered the Spicer u-joints that have the 1.063 and 1.125 caps and the larger caps don't fit the pinion or t-case, they are just slightly too large. The smaller caps fit but seem to be able to wiggle too easily side to side in curve of the cup. What's the deal? I thought these trucks took the funky size u-joint. Need to figure out what the correct one is so I can put this back together. Any help would be great!
Old Feb 11, 2024 | 07:48 AM
manicmechanic007's Avatar
manicmechanic007
The U joint that has the two different cap sizes is just for the rear axle flange that uses U bolts (not you)
That was the rear u joint rear shaft
The style that uses the bolt on flange uses a Spicer / Dana 5-7438x (you)
F2TZ-4635-E should be the more expensive Ford greaseable one
Old Feb 11, 2024 | 09:58 AM
dremtofford's Avatar
dremtofford
is it the same for an 88 f150 4x4 manual front driveline. tried looking it up on lmc and they have a big bunch of sizes.
Old Feb 11, 2024 | 05:29 PM
manicmechanic007
Right, same
They are 1350 series in size IIRR
Look them up on the AutoZone site or just plain old Google
Recently had a driveline rebuilt for a 99 F250 with a blown out CV joint stub and ball
It used the 1350s too
mstaser
May 9, 2025 03:57 PM
NW 150
18
Jul 2, 2012 01:48 PM
Fordziller
Mar 30, 2007 11:20 PM
SeaDooPhil_78
Dec 28, 2003 05:19 PM
