I need to replace my carrier bearning and know I will need to take off the yoke by the carrier. I can't find any information on what size that nut is. Just want to make sure I have the right size tools before I start taking everything apart.
If you have an Advance Auto Parts locally, they should stock the SD manuals (mine does). It will tell you in the book. Wish I could be more help to ya.
I think he is talking about the big nut that holds the yoke to the pinion. Not the 4 bolts that take off the driveshaft.
Its to bad I didn't find this a couple days ago....I just had mine off. I know it is bigger than 19mm.
Sorry for digging up an old thread but does anyone know what size that nut is? The only size I found on another forum was 33mm for an '02 truck. Mine is an '04. Are they the same? Thanks in advance.
I have pulled many a pinion flange, without needing to rest preload.
Remove , make your repair , replace .
Pinion has nothing to do with his carrier bearing issue.
