1999 E350 Cools Too Well?
Old Feb 13, 2024 | 09:49 AM
Don Ridley's Avatar
Don Ridley
Maybe you just need to repair the temperature gauge. The sending element is a resistor that changes with temperature. You can find the resistance/temperature relationship with a Google search. The temperature gauge measure a change in voltage as the resistance changes. The cluster on your van is relatively simple and the temperature signal is likely not getting to the cluster due to a broken wire or bad connector.
You can find wiring diagrams to troubleshoot the signal here:
https://charm.li/Ford%20Truck/
See the sticky post about the cluster anatomy at the top of the van subforum.
Old Feb 14, 2024 | 04:49 AM
manicmechanic007's Avatar
manicmechanic007
Originally Posted by Youngan
I think there has been a misunderstanding. I have never at any point had trouble with the heater; it has always worked great.
Thanks for the clarification on the Fail Safe Thermostat. I was not familiar with those, and had to look it up. Now I see what you’re talking about there. Yes, this van has the bottle. I’ll try raising the front to see if it burps.
You mentioned never gets to operating temperature
That means low or no heat as a byproduct
If you have good heat, you have a indicating issue
Thermostat staying closed until the 25 minute mark? What?
Old Feb 14, 2024 | 08:43 AM
Youngan's Avatar
Youngan
4wd Low
Agreed that there has been an indicating issue, as detailed in an earlier post.
Yesterday, I installed an aftermarket digital coolant temp gauge. And it seems to indicate that everything is working normally. As one would expect, coolant temp starts rising steadily from ambient right after start-up. It eventually reaches 191°, then holds steady there.
What was throwing me off is that the lower radiator hose never gets hot; in fact, it never gets more than luke warm. This is counter to my many years of experience working on import vehicles. I am now assuming that this is due to the fact that this thing has a HUGE radiator, I’m operating it with no load, and the fan spins all the time (even if not in “lock up” mode).
Yes, 20 minutes (or more) to thermostat opening. Keep in mind that this is at idle, in ambient temps below freezing, and with the heater fan on high (pulling heat out of the system) starting at about the 10 minute mark.
Old Feb 27, 2024 | 10:42 PM
Youngan's Avatar
Youngan
4wd Low
Ok, just to close the loop on this discussion, in case someone finds the info useful in the future:
I loaded up the truck (to 14,000 lbs GVW, as it turns out, 2,500 over it’s rated max of 11,500) and drove it 3200 miles to Alaska (from Colorado). Ran at 70-75 mph nearly the entire way, except on the frost-heaved sections of the Alaska Highway, where it’s far to rough for that. The digital coolant temp gauge that I installed would go up to about 185°f after several minutes of driving and stay there most of the time. Pulling steep hills at high RPM in 2nd gear would see the temp rising rapidly to about 200-205°, and then it would start dropping down to about 185° again. I’m assuming this was due to the thermostat opening a bit wider, but having a slight lag. I had plenty of heat, even with the Alaska winter temps. In fact, I usually had the fan on low, and the temp selector at about the middle position.
So as far as I am concerned, no cooling system problem; just a misinterpretation on my part.
Old Feb 27, 2024 | 11:01 PM
etinpa's Avatar
etinpa
Thanks for filling us in on the final resolution.
I guess "overloaded" for 3200 miles is a pretty good test!
Now all that remains is a trip to Death Valley in the summer.
Old Feb 27, 2024 | 11:35 PM
Youngan's Avatar
Youngan
4wd Low
I also meant to report that I averaged about 9.3 mpg. I was pretty happy with that, given the load and the speeds.
A Death Valley run would indeed be a good test, but my plan is to sell the truck soon. I bought it specifically for this trip, and now that job is done.
eire49
17
Jun 6, 2021 11:32 PM
mumblemouth
Sep 18, 2019 10:31 AM
FordExplrer
Dec 31, 2016 11:55 AM
gcpommom
Aerostar
Dec 13, 2011 09:04 PM
nick150
Dec 2, 2004 10:13 AM
