Sponsored by: Real Truck
2004 HPOP replacement
Old Feb 9, 2024 | 10:42 AM
Zach H.'s Avatar
Zach H.
4wd Low
Hi, i have a 2004 F250 with a 6.0(early model) I am about to do a HPOP replacement and I am trying to gather a list of other things in the general area that is a good idea to replace also, I already know of the head gaskets/studs. Also if anyone has recommendations on parts would love to hear them thanks!
Old Feb 10, 2024 | 06:30 AM
Baylinerchuck's Avatar
Baylinerchuck
Any reason why you want to do the head gaskets? Do you have a known leak? Oil cooler and EGR need to be at a minimum checked, but would recommend replacing.
The other MUST…..move this post over to the 6.0 section of the forum. You’ll get way more activity and recommendations over there. That side of the fence will teach you everything you need to know about these engines.
See you over there!!
Old Feb 10, 2024 | 09:38 AM
Zach H.'s Avatar
Zach H.
4wd Low
Yes I believe I have a very small leak in one of my head gaskets, it’s not enough to change the color of the oil but there is a slight sheen of coolant on the top if I let it sit long enough.
also this is my first day on here by move post you mean re write it in the 6.0 section correct?
Old Feb 10, 2024 | 07:28 PM
Baylinerchuck
Definitely rewrite the post in the 6.0 section. It will get a bunch more traffic. It could be the oil cooler instead of a head gasket, at least hope it is. Welcome to FTE.
chuck
Scaleguy15
Apr 24, 2023 08:01 AM
Aknfreighter
Dec 21, 2021 08:21 PM
grimmdr
Jan 7, 2016 02:44 AM
chuiee
2004 - 2008 F150
Nov 29, 2003 02:32 PM
