Not sure…….
Old Feb 9, 2024 | 10:18 AM
PSasquatch's Avatar
PSasquatch
Not sure…….
What is this?
Found this. Mechanic deleted some things
Can this be bypassed?
Old Feb 9, 2024 | 10:37 AM
OBS460's Avatar
OBS460
The charcoal canister should not be deleted. The fuel vapor from your tank vents through the charcoal filter and prevents raw fuel vapor from venting under the hood. If you delete it there will be a strong gas smell. If you plug it your tank will swell when it gets hot because there is no vent anymore. Everytime you open your tank you'll get a hissing noise or it will spit at you because of the pressure built up.
You do want to make sure the rubber lines going to it and to the PCV aren't brittle or cracked.
Old Feb 9, 2024 | 10:50 AM
PSasquatch's Avatar
PSasquatch
What is the coffee can looking thing? I thought that was the canister.
Old Feb 9, 2024 | 11:10 AM
Jim_K's Avatar
Jim_K
The "coffee can" is your vacuum reservoir.
rla2005's Avatar
rla2005
The coffee can looking canister on the passenger side inner fender is the vacuum reservoir for the emissions system.
No relevance to the fuel vapor (EVAP) system.
Old Feb 9, 2024 | 11:26 AM
OBS460's Avatar
OBS460
The EVAP cannister should have a line in from the tank vent and a line out to the PCV which IS hooked to the vacuum system.
Old Feb 9, 2024 | 11:27 AM
OBS460's Avatar
OBS460
The EVAP cannister should have a line in from the tank vent and a line out to the PCV.
Old Feb 9, 2024 | 01:38 PM
rla2005's Avatar
rla2005
On a 4.9L engine truck the CANP is plumbed to the throttlebody. There is no PCV connection like the 7.5L gas engine trucks.
Old Feb 9, 2024 | 02:20 PM
OBS460's Avatar
OBS460
That is your connection to route it through your PCV system.
M2HB
Aug 18, 2023 02:05 PM
kegger66
29
May 30, 2023 05:00 PM
RonC80
Jul 28, 2021 04:34 AM
Moby2005
Mar 2, 2018 08:56 AM
jonmammenga
Jan 10, 2017 12:08 AM
