USB TO USBC
Old Feb 7, 2024 | 09:26 AM
buckeye2019's Avatar
buckeye2019
4wd Low
USB TO USBC
Has anyone changed out the USB plugs to a USBC to accommodate for the new iPhone. If so do you have a part number that would fit in a 2018 f250 Lariat. Thanks
Old Feb 7, 2024 | 09:39 AM
llr350's Avatar
llr350
You should be able to just get a different cable like this
Amazon Amazon
Old Feb 7, 2024 | 09:56 AM
JoeUser's Avatar
JoeUser
Originally Posted by llr350
You should be able to just get a different cable like this https://www.amazon.com/AmazonBasics-...1zcF9hdGY&th=1
I think that USB-C has a higher power rating IIRC, so if the OP is expecting that benefit an adapter only changes the connection and would still only provide what the USB-A provides from the truck. Which isn't much, from what I've seen in my '20 XLT.
Maybe the later year models that offer USB-C have a particular module that could possibly replace the earlier pre-USB-C module, I dunno...
Old Feb 7, 2024 | 10:46 AM
llr350's Avatar
llr350
USB-C may have higher power, but it may not. My home charging dock has 2.4 Amps on the USB-A.
No idea what the truck A or C are capable of.
Old Feb 7, 2024 | 10:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
All USB-C cables must be able to carry a minimum of 3 A current (at 5 V, for 15 W) but some can carry 5 A current (at 20 V, for 100 W).
Old Feb 7, 2024 | 11:40 AM
buckeye2019
4wd Low
Guys I just want to lnow if you can simply plug and play a new ford USBC into a 2018 UBS. Will it work? i don't care about voltage? thanks
Old Feb 7, 2024 | 11:42 AM
nickshu's Avatar
nickshu
I just bought adapters. They work great. This transition is going to be a pain for the next few years so I bought a bunch of them and stow them in various places...work, home, luggage, cars, etc.
https://www.amazon.com/gp/product/B079LYHNSR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
https://www.amazon.com/gp/product/B09SZ5NHF4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Old Feb 7, 2024 | 11:48 AM
4wd6.7L's Avatar
4wd6.7L
I thought I read that installing the OE 20-22 USB C port in a 17-19 requires upgrading Sync 3 to 3.4. If I find the thread where I might have read that I will add it. Some other options would be to wire in an aftermarket USB C port or even easier, just use an adapter in the 12v port (cig lighter). I use something like this in either the 12v dash port or more often in the center console. https://www.bestbuy.com/site/insigni...?skuId=6495000
Here is one discussion on the USB C retrofit- https://www.ford-trucks.com/forums/1...17-2019-a.html
Old Feb 7, 2024 | 04:18 PM
speakerfritz's Avatar
speakerfritz
If you convert the usb to usb-c, look for a setup the confirms to usb-c PD which is what the iPhone needs.
Old Feb 7, 2024 | 08:56 PM
Joe T's Avatar
Joe T
Its not plug and play
hondaslave1342
May 15, 2022 12:43 PM
tseekins
2009 - 2014 F150
Mar 17, 2020 05:35 AM
Ridenred333
Mar 2, 2011 11:36 AM
jamesemery728
1983 - 2012 Ranger & B-Series
Dec 24, 2009 09:54 PM
Scrib43
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 9, 2003 02:35 PM
