Help! Cant find the gremlin
Old Apr 8, 2024 | 10:38 AM
  #31
rla2005's Avatar
rla2005
The voltmeter has nothing to do with the alternator exciter circuit. Power flows from the Ignition Switch when it is in the Start or Run position. From there it goes to the Charge Indicator bulb in the cluster. There is a shunt resistor in parallel with the bulb in case it opens. This signal leaves the cluster then makes it's way to the alternator. I suspect the alternator has a bad diode which causes the output to have significant harmonics which is affecting the computer.
Old Apr 8, 2024 | 01:04 PM
  #32
indy358's Avatar
indy358
Originally Posted by AuroraGirl
It goes through the voltage light on the dummy lights in order to pass through the 194 bulb, which acts as a resistor, this resisted ignition is what is used to excite the alternator to charge. if you put an LED in the place of the incandescent it will cause the same issue, for example.
The small plug on the alternator is what connects to the dummy light as I unplugged it and the light came on. Is it just a return line to tell the circuit that there is power coming from the alternator?
Old Apr 8, 2024 | 01:07 PM
  #33
indy358's Avatar
indy358
The original alternator tested bad so I replaced it with a new one that tested good three times. I guess it would be possible to have a bad diode in both but I’d think that would show up in the testing, wouldn’t it?
Old Apr 8, 2024 | 01:25 PM
  #34
rla2005's Avatar
rla2005
The Light Green/Red wire is the supply voltage to turn on the alternator. Not sure how the Charge Indicator would turn on with the connector to the alternator removed.
As far as testing the alternator goes most places do not test for bad diodes,/excessive ripple on the output anymore.
Old Apr 21, 2024 | 07:07 PM
  #35
indy358's Avatar
indy358
SO, here’s where I’m at. I replaced the volt gauge since I had already ordered it but it made no change. I unplugged the green/red wire at the connector by the battery and checked the voltage. It’s getting 11.8 volts with the truck running. I plugged that back in and checked voltage at the green/red terminal going to the alternator and it had the same voltage. This tells me the alternator exciter is sending power to the alternator just fine. However when I plug the alternator in the violent shuddering immediately begins. I did change out the alternator again but it made no difference. I also made sure all the lights in the cluster are good so they shouldn’t be an issue.
I just don’t know what else to check. The problem seems to be occurring when the alternator is on and charging the battery. What could it be?
Old Apr 22, 2024 | 09:43 AM
  #36
rla2005's Avatar
rla2005
I disagree, the voltage should increase since there is exciter voltage to turn on the alternator when the Light Green/Red wire is connected.
I am not following you here. Your previous test was done with the alternator output not connected to the battery?
Old Apr 22, 2024 | 10:40 AM
  #37
indy358's Avatar
indy358
I tested the line coming from the ignition to the alternator, the exciter line. With the engine running I get 11.8 volts at the connector by the battery and also at the alternator plug. With the exciter disconnected the engine runs fine but, of course, the alternator isn’t charging. When I connect the exciter the engine starts stumbling.
Old Apr 22, 2024 | 10:51 AM
  #38
rla2005's Avatar
rla2005
With the alternator "turned on" the alternator charges at a higher voltage than static battery voltage. I would expect something greater than 13 VDC or a little higher. You stated the voltage measured is the same. To me the alternator is not charging or the fuse link between the alternator and battery is open. Which would not explain why having the alternator running as designed causes a stumbling problem if it is not actually getting to the battery. If the voltage was a lot higher than static battery voltage that would lead me to believe the voltage regulator was bad.
Old Apr 22, 2024 | 10:59 AM
  #39
indy358's Avatar
indy358
The exciter line, not the battery is getting 11.8 volts from the instrument panel with the engine running at both the connection by the battery and at the terminal that plugs into the alternator. The engine is running smooth at this point. When I plug the exciter into the alternator I get 14 volts at the battery but the engine starts stumbling. Through the voltmeter I can see the voltage fluctuate a little every time the engine stumbles.
something is happening when I plug up the exciter line that is causing the stumble.
Old Apr 22, 2024 | 12:33 PM
  #40
rla2005's Avatar
rla2005
That makes a little more sense I suppose.
Since you have installed more than one "new or rebuilt?" alternator we can cast a less leery eye towards that. One check I would do is use a jumper cable with one end attached to the negative battery terminal, then attach the other end to the alternator bracket. Start the engine then see if the stumble remains with everything connected. Doing this will help eliminate a poor ground to the engine. Usually you would get slow starting, but this needs to be eliminated.
If that is good try running a jumper lead from the battery (+) or fused source directly to the alternator end of the Light Green/Red wire. Then see if the stumbling remains. This will eliminate the exciter circuit as the cause.
Old Apr 27, 2024 | 06:04 PM
  #41
indy358's Avatar
indy358
I had already run an extra ground, which did nothing. I unplugged the exciter line from the dash and fed 12v straight from the battery and the stumble cam back.
I talked to a local guy that deals with these trucks a good bit and he suggested trying a new ECM. I had discounted this because the truck ran fine without the alternator. I figured if it was the ECM then it would act up all the time. In his opinion the reason it stumbles when it gets the full 14v is there's something wrong with the ECM. at 12v it's fine but when it has full power it tries to compensate for whatever is wrong and stars causing problems. So, I guess at this point I will order a ECM and see what happens. If that doesn't fix it I guess I'll just part it out and start over. Hopefully I can get most of my investment back selling parts.
Old Apr 28, 2024 | 12:45 PM
  #42
AuroraGirl's Avatar
AuroraGirl
flawed reasoning but if you have a 95 and earlier truck... checking the caps isnt a bad idea.
Old Apr 28, 2024 | 02:08 PM
  #43
Soup bean's Avatar
Soup bean
How old is your battery? Maybe the alternator is trying to charge a defective battery.
Edit: How have you been keeping the battery charged during all of this?
Old Apr 28, 2024 | 10:00 PM
  #44
indy358's Avatar
indy358
It’s the only reasoning I have left. I have replaced and or tested every thing else it could possibly be. The only thing left is the ECM.
Old Apr 28, 2024 | 10:02 PM
  #45
indy358's Avatar
indy358
The battery is brand new. Whenever I’m not working on the truck it’s hooked to a battery tender.
