Bedside patching advice
Old Feb 6, 2024 | 08:46 PM
idealtrucks's Avatar
idealtrucks
I need some advice on how to go about patching the lower rear part of my bed. I have some 18 gauge metal. Should I try to make a patch on the spots that are bad, or buy a patch panel and replace with that?
Old Feb 7, 2024 | 12:24 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Feb 7, 2024 | 01:51 AM
karljay's Avatar
karljay
I'd buy the panel and weld that in. Acid etch all parts inside and out, then paint inside and out.
I did mine with POR15 under side and frame, then painted the bed inside and out after fully sand blasting and acid etching.
I'd also make a jig that lines everything up before you cut the old parts out. Basically bolt on some sq tube or angle iron so that it shows exactly where the new panel goes. Takes a bit of extra work, but you know it'll be exactly where it should be.
Old Feb 7, 2024 | 06:26 AM
73FOMO's Avatar
73FOMO
Agree patch panel. Replied to your duplicate post as well.
Old Feb 7, 2024 | 08:01 AM
idealtrucks
Thanks for the advice guys.
Does anyone have experience on the quality of Tabco vs AMD? AMD is cheaper after shipping. Says it's 19ga. I emailed Tabco several days to see what guage theirs is, but haven't got a reply.
Chicago Fire Patrol
2338
Apr 19, 2025 04:29 PM
idealtrucks
Feb 7, 2024 08:35 AM
CelticOne
29
Jul 10, 2021 07:09 PM
Powerhour
1947 and Older Ford Trucks
Nov 4, 2018 06:30 PM
mikerogers56
19
Aug 1, 2016 02:53 PM
