Spring Swap - Definative Word
Old Feb 9, 2024 | 06:12 PM
ArmyRover's Avatar
ArmyRover
Originally Posted by Antonm23
Nope, the shims you linked above are 2 inches wide, an Excursion needs a 3 inch wide shim. Here is a link to the correct ones.
https://www.wfoconcepts.com/i-305047...im-3-wide.html
I appreciate the confirmation I rolled the dice and ordered the 3”
Old Feb 18, 2024 | 11:56 AM
mcquojo's Avatar
mcquojo
Trailering
Procomp 22210 2” front procomp 22415 4” rear
I’m about to to start ordering parts for the @pirate4x4_camo ProComp lift, and I noticed the fronts are +2 and the rear is +4. Why is this set up using 2 different spring heights? I understand the excursion is 2” less than F250 and +2 gives me closer to 4”. Does final ride height equal -2” front rake, lifting 4” in the front and 6” in the rear? Looking at some picture ya’ll posted the rake doesn’t look to be that noticeable.
Sorry if this seems like a stupid question. I have plenty more if you’d like to hear them.
Old Feb 18, 2024 | 12:07 PM
Antonm23's Avatar
Antonm23
The reason the springs are different heights is because that allows you to eliminate the factory lift block and use an all spring lift.
You end up getting a level lift of around four inches with no blocks, using the Pirate Procomp recipe.
Old Feb 18, 2024 | 12:19 PM
mcquojo's Avatar
mcquojo
Trailering
Makes sense, glad I asked. Thank you!
Old Feb 18, 2024 | 06:45 PM
mcquojo's Avatar
mcquojo
Trailering
If I remove the rear block, I’ll be removing the bump stop tab. Without the tab, it looks like the bump stop will make contact with axel if the suspension bottoms out.
Old Feb 18, 2024 | 07:09 PM
Antonm23's Avatar
Antonm23
There are options there too. Some just run without a bump stop, some ( myself included) use the PMF air bag tangs and airlift supplement air bags with an internal “jounce bumper” ( that’s what airlift calls bump stops for some reason).
Search for airlift 88340 kit for more detail.
Old Feb 18, 2024 | 07:10 PM
JSPEX's Avatar
JSPEX
Take a look at the PMF airbag tang/bumpstop plate. That's what I and others have used. I have airbags, but I assume it will work for the bump stops as well.
tfunk88
Dec 20, 2018 08:00 PM
BMXpert23
Aug 3, 2017 01:48 PM
rickdavis81
Jul 1, 2013 09:27 PM
crazer42
Mar 14, 2009 03:10 PM
romara
Feb 26, 2009 08:08 PM
