carb problem
Old Nov 24, 2003 | 11:24 AM
hotbbb's Avatar
hotbbb
Thumbs up carb problem
i have a motorcraft 2100 carb and when i a driving my car its ok. but as soon as my car warms i can hear a crackling noise . i think it is predetonation. my timing is set correctly. i was wondering if it could be something to do with my carb. If my carb was running too rich woukld i have this problem because as soon as igo above 30 miles an hour it goes away. thx.
Old Nov 24, 2003 | 11:57 AM
bubbaf250's Avatar
bubbaf250
Pinging can be caused by either fuel/air mixture (too lean, not too rich) or too much ignition advance. You really need to identify the exact circumstances when it occurs.
There are various metering systems in the carb that interact to regulate the mixture under different conditions.
In the distributor, there are vacuum and mechanical advance systems that determine ignition timing advance, either together or separately, under different conditions.
Can do describe a little more specifically when you hear the noise? Is it when accelerating? Accelerating light or hard? When cruising at steady speed? When engine load increases (like trying to maintain speed up a hill)? Does it vary with vehicle load (e.g., when towing)? Have you noticed any difference with higher octane fuel?
Also, which engine do you have? What is the base ignition timing now?
Check out these pages for some general tuning tips for ignition timing and fuel mixture on a stock engine:
http://home.earthlink.net/~bubbaf250/perf/perf02.html
This was written for the 351M/400 engine family, but it is applicable to most other Ford engines with OEM 2V carbs.
Old Nov 25, 2003 | 02:48 PM
hotbbb's Avatar
hotbbb
i only have this problem when my engine warms up and i a going up a hilll or when i push the gas down suddenly.thx
Old Nov 25, 2003 | 05:44 PM
bubbaf250's Avatar
bubbaf250
Try backing off the vacuum advance. Procedures are described in the link I posted above.
