leaking carb
Motorcraft 2100
Been getting really(!) bad mpg. Did standard tune-up. No good. Then........
Came out of store tonight and smelled gas from under hood. In front of carb, on top of manifold was fresh gas. I check all screws,etc. and all are still tight. No broke hoses, etc. Guy at work says I should try replacing "accelerator pump"(?) before thinking about rebuild/replacement.
My question is: Is this something a novice with few "good" tools can/should do and if not what is the est. (ball park) $ amount to have this done by a shop?
Much appreciation for any help given.
If this doesn't do it...you will probably have to tear into the carb...these carbs are pretty straight forward, you should be able to figure it out. I paid like $35 for a kit to rebuild mine, and I wouldn't imagine a shop would charge you more than 2 hours to do it.
BTW-I am getting 9 mpg with my 390
