Having trouble finding a specific running board set......
Looking for a set of these running boards, near Kansas if possible. The problem is I don't know what year they came on, what the part number is, etc. Some with the SUPERDUTY backing plate has the slats on the the chrome portion, I am looking for the ones with the solid full length step pad with the backing plate. I can't find them listed on Ford parts sites or under the accessories section. Any help is appreciated! Thanks
Those are what my '22 came with. Window sticker calls them out as '6" angular chrome step bar'
Took them off long ago so I can't read part numbers.
I was thinking the same. They sure look like those that were on the 2022 F 350 I just traded.
Originally Posted by shawnee1
If you are willing to share your '22 VIN in a PM, the OP may be able to look up the part number at a dealer parts counter or on-line.
Here's the VIN for that traded truck if it helps anyone. The window sticker does indeed show them as 6" angular chrome step bar. Which is part of the XLT Premium package.
I don't think these are limited to 22, I bought a pair from someone to put on my 22 and I am pretty sure he said he had them sitting in his garage for a few years but I found mine by searching FB marketplace and was using the term "OEM (or factory) Super Duty _____" where the _____ was side steps, nerf bars, or any term that means the same thing. I wasn't looking for this specific pair by any OEM but glad I found them as they also help as a mudflap a bit and keep more crap off my truck.
I have those on '20 XLT. It is on the window sticker listed as " 6" angular chrome step bar ". I just do not see many with the SUPER DUTY filler panel.
Is the backing blocker a separate part? If yes, does anyone have a part number for crew cab length?
tia
I think it called the running board reinforcement, the parts diagram just doesn’t have a good picture of it. But it appears to be just a filler panel with superduty on it.
