Need Advice - trashed engine
So quick background, I bought a 1978 F150 as a project right at the start of COVID thinking I would have time off to work on it. Well I am in the military and got a total of about a week off so that went out the window and the truck has sat covered since then in my yard. Well I finally got 100 other projects done and decided to dig into the f150.
I bought the truck initially to LS swap it. I know, I know. Well I found a donor truck that had been in a minor accident but the owner was selling it cheap because according to him “bent some suspension stuff”. I had it towed home and after getting under the truck all that broke or bent was the sway bar end link and the drivers side tire Rod (he drove it home and the tire Rod broke when he backed it in his driveway). Well literally $16 from rockauto and $100 for a drivers door and fender that are the perfect match and the truck is 100% running and I am actually using it as a spare truck when the kids need it.
I started think I would just get the ford running with the motor that is in it (supposedly a 400) with a c6 trans and the transfer case. I also have the original manual transmission and transfer that was in the car before and a second motor that is supposedly a 351M. I never looked at the motor in the truck over the 3 years because I never intended to use it and selling it seems like I would only get a few hundred dollars. So before I tried to start it, I decided to turn it over by hand on the crank bolt. It turned but only would got 90 degrees either way before it would stop on something that felt like metal to metal contact. Well I pulled the valve covers and the far rear passenger side intake push rod was bent pretty bad. Ended up pulling the intake and heads today and this gets me to the point of the questions.
the cylinder that had the bent push rod had some rust in it where it looked like water was in it, looked around the cylinder and there is a good sized crack/hole in the side of the cylinder wall where my guess it it cracked when someone tried to start it with water in the cylinder so the block is scrap (the piston tops had .040 on them whatever that means). Now I still have the other complete engine and the heads that I took off look fine but I have no idea what is in either motor parts wise (the spare motor looks bone stock like it’s never been apart). I haven’t taken that motor apart yet, that’s a project for another weekend.
so here are my questions/options:
Options 1-3 also include having to buy a new ignition module, new distributor (wires on the truck are really nice), building an entire exhaust and refreshing the c6 and checking the transfer case because who the heck knows what condition they are in. Probably also have to get new driveshafts unless the manual trans are the same size as the c6 setup.
Option 1: Assuming that between the two motors I have enough good parts to either do a quick driveway refresh to get the motor running, I assume all I would need to do is take them apart, check for any obvious issues and for the price of a new gasket set I COULD be up and running or I could be pulling the engine apart again because bad cam bearing, bad main bearings or excessive blow by from worn rings. Is this worth it to try?
Option 2: If I take the other motor apart and the main parts look ok I can take them to a local machine shop to have it clear, checked for cracks etc and have new bearings and piston rings in at a minimum, if the cylinders need bored or the heads need decked, I would have those costs as well. I am guessing $2-300 for the machine work, potentially $400 for new pistons and a gasket set. Maybe $1000-1500 for a refresh but still a stock motor.
Option 3: same as option 2 but put a bigger cam, raise the compression a little with either deck work or pistons and other wise the same stuff as option 2. A total cost of probably $2000-2500 or $1000 more than option 2
Option 4: LS swap it. Not my first swap so I can do all the work. The problem with this option is I have that other truck fully functional and I have to waste that now so I would probably look for another truck. Buying another truck with engine, trans and transfer case will probably be around $1500 or so. I could probably do the remainder of the work for about $1000 because I would want to freshen the motor, put a nice cam in it etc. cost here would be $1000 if I use the truck I bought initially as the donor engine up to $2500 if I find another.
Option 5: sell the rolling chassis as is and just do something else. Sort of took the wind out of my sails when I found the hole in the motor and have to do a full rebuild. Not sure what I could get for it, frame is in great shape, previous owner put in new floor pan (didn’t do the best job), cab corners are good, truck has a lift, front disc brakes and looks pretty cool even in 4-5 colors because of the flare side bed.
I know that’s a novel and I know I am asking on a ford forum where everyone is going to default to the non swap but was hoping to at least get a cost sanity check, I just want to get it running for as little as possible to enjoy it and tinker around.
Good luck.
Good luck.
I'm guessing you're partially considering the SBC swap due to your previous comments about fuel economy. You mentioned in the other LS swap thread that 20MPG is what you'd expect. Not gonna happen brother. Forget about this fuel economy nonsense. You're going to be driving a 4000+ pound truck that has a coefficient of drag that's not much better than a rectangle. 0.65 is probably a reasonable number which is essentially horrendous for fuel economy. It doesn't matter how modern of an engine you put in the truck. Physics don't care. That truck is simply going to have an incredibly high road load torque value. BSFC is determined by road load. Yeah, modern EFI engines are going to be more efficient to some degree, but there's a stopping point and it ain't 80% above what an old tech carb'ed engine will do. You MIGHT gain 2MPG, but WHO CARES? I simply do not understand all of the fuel economy threads on this forum. You're driving a 50 year old truck that was designed at a time where no one, and I mean no one cared about fuel economy if they were driving a full sized truck. These trucks were essentially draft horses and much like draft horses they were bred to work, nothing else. You have to feed them more as a trade off for the capability given the technology at the time.
I'll give you an anecdotal example (albeit one backed up by 20 years of engineering experience in the auto industry) to demonstrate my point. Our Ram 1500 with the puny little 3.6L struggles to get 20 MPG highway on a good day. That truck has a lower Cd, a more efficient driveline, a very numerically low final drive ratio, and the most modern controls that an OEM has to offer. You're not going to get anywhere close to that with an older tech worn out engine with higher displacement, especially one that's transplanted into an ancient truck made with Henry's quality steel.
So, I would humbly submit that you go with option 3. You clearly want a little more power out of it, but I think you're getting soured on the cost component. Option 3 is the best balance between time and money in my opinion. It will bolt right up, major supporting components don't need to change, it will be more exciting than stock, and will be more than reliable assuming you install everything correctly and choose quality parts.
Best of luck. Let us know what you do and post your updates. Looking forward to reading what you decide to do.
I appreciate your feedback on the option 3 time vs cost.
I don't like the 351m/400 and if I had an excuse to go to a 351W or something else I would do it. Depends on the truck though, if it was a pretty much factory correct, survivor truck I would try to stick with what it came with. If it's already a frankenstein who cares. But then the c6 still wouldn't bolt up to anything but a 385 or 335 series
LS swaps are cool, but part of what makes these trucks cool is you can fix it with a handful of tools.
You may have just given me the new/best option yet!
