I'm getting the internal tpms sensors installed so I'm using Forscan to update the truck to show the tpms picture with all 6 wheels. I've updated BdyCM-BCM 726-10-01 module from 200 to 201 and wrote the change. I turned the truck off and back on but the change that should now show the TPMS for the truck still does not show. I know I need to get the actual sensors installed and that is happening tomorrow. But I thought that when I updated the system the basic picture would show up, /what am I missing/forgetting to do. Thanks.
So from what I can tell, I've done all the required updates to have the TPMS screen display. Not sure what I am missing. Any help is really appreciated.
thanks so very much. I looked at all the IPC updates and saw one for trailer tpms but nothing for truck tpms. The IPC options are:
Automatic Engine Idle Shutdown - Disable (20-22)
Disables Drivers Seatbelt Chime (20-22)
Disables All Seatbelt Chimes (20-22)
Adds Average Speed to Trip/Fuel Menu
Disables Door Ajar Chimes
Disables Triple Ding at Start Up (20-22)
Disables Triple Ding at Start Up (23)
Fuel Tank Size (20-22)(23-Gas)
Fuel Tank Size (23-PSD)
Turn by Turn NAV
Temps on Gauges
DPF% on screen
Trailer TPMS Enable
Auto Regen Checkbox
Disables All Seatbelt Chimes (23)
Now I noticed with the BCM modual, it says (23) after tpms. I gather that means for 23 model year;. But I can't find a modual that is for 22. I'm sure it is something simple I am missing.
