Sponsored by: Auxito
Clean MAF ?
Old Nov 24, 2003 | 09:59 AM
50th ann's Avatar
50th ann
Clean MAF ?
What should I use to clean the MAF sensor and how should it be done? It looks to sensitive to use the wrong stuff.
Old Nov 24, 2003 | 10:15 AM
stepman's Avatar
stepman
I usually just blow it or carefully wipe it off. You could also spray it with some electrical parts cleaner.
Old Nov 24, 2003 | 10:20 AM
emtabmm's Avatar
emtabmm
Here at the dealership we use electrical spray cleaner with a pipe cleaner followed by gently compressed air...
Old Nov 24, 2003 | 11:39 AM
LxMan1's Avatar
LxMan1
Carb cleaner works good too. If you are actually going to wipe it with something, be very careful. The wires are very thin and if you break one, then you will have to buy a new unit. I usually just spray mine with brake and parts cleaner( It doesn't leave a film) and they work fine.
Jimmy
