vacuum issues
Old Feb 27, 2024 | 02:33 PM
tbear853's Avatar
tbear853
Originally Posted by markwinans
............It is probably lean due to that huge crack in the exhaust manifold. Would you concur?
My thoughts. Headers ... if tuned right ... scavenge exhaust from other cylinders using the pull of the flowing exhaust of other cylinders sharing that header, a vacuum of sorts can be created in the header. Exhaust being vacuumed out is easier than pushing it out, and vacates the cylinder faster for a better intake stroke filling it. Unless a really trick set of manifolds, I've never seen a cast iron manifold that preforms near like a tuned header ...rather most just serve to get used exhaust moved into a pipe to a muffler, etc. There are exceptions, but these trucks didn't get those "cast iron headers" A cracked manifold might leak and allow a slight drop in back pressure for that one cylinder, but not enough to lean it out like a cracked header can do as a header looses efficiency then. A cracked exhaust manifold will tick loudly, stink like hell, even let air into the exhaust leading to exhaust pops as unburned fuel in hot exhaust suddenly has oxygen maybe.
Brynjaminjones
13
Feb 5, 2019 03:48 AM
Zazoos
Oct 7, 2016 09:21 AM
mgreen
Jun 12, 2014 10:37 AM
Jodell
Mar 5, 2009 08:23 PM
crescentwrencher
Mar 28, 2008 01:02 AM
