Sponsored by: Kumho
Ball Joints - do 'em myself???
Old Nov 24, 2003 | 07:22 AM
bp_sigchi's Avatar
bp_sigchi
Exclamation Ball Joints - do 'em myself???
Hey guys. '92 Ford F150 1/2 ton. So, I have no air compressor or impact wrench, but I can probabily get my hands on one. I've been told to rent a spring compressor also. But, more so, I've been told to have someone else do them.
Thoughts?????
This weekend I have 3 days to pull off this trick. I'm assuming you do upper and lower at the same time, on both sides. Anyone have any good web-pages on how to replaces these? I don't think my Hanes manual outlines it real well, from what I remember.
Give some advice! I know no one in my hometown who has done these themselves, but there's a first time for everything....
Thanks!
bpsigchi
92 F150 1/2 ton
Old Nov 24, 2003 | 09:14 AM
97HD4X4's Avatar
97HD4X4
I just did mine a month ago. Its on a different truck, but it isnt hard at all. Make sure you get a ball joint too, I believe auto zone rents them out. As for the compressor and air tools. you dont need them, however... they would make the job a little faster.
Old Nov 24, 2003 | 09:35 AM
bp_sigchi's Avatar
bp_sigchi
You're a good man. I think you meant to say something else here:
Ball joint press? Remover??
Old Nov 24, 2003 | 10:47 AM
97HD4X4's Avatar
97HD4X4
LOL.... yeah thats what I meant to say. 'Ball joint tool' Auto zone will also rent you a spring compressor.
Old Nov 24, 2003 | 11:44 AM
rebocardo's Avatar
rebocardo
FWIW: The ball joint kit Autozone rents does not come with the right adapters for the Ford Dana 44. What I did, until I bought my own set was use a large impact socket.
Old Nov 24, 2003 | 12:21 PM
bubbaf250's Avatar
bubbaf250
Even with the considerable cost (approx $100-150) of a proper ball joint tool kit, you will save money over paying someone to do just two of them (e.g., upper and lower on one side) for you.
Autozone has a procedure described on their web site:
http://www1.autozone.com/servlet/UiB...3d800a9fe1.jsp
Old Nov 24, 2003 | 01:00 PM
mattsf250's Avatar
mattsf250
HARBOR FREIGHT.
they have about 4 different ball joint tools, one made for 4x4....they are all between 40, and 60 bux, and offer normal hf quality...they will work however.
if you have an impact wrench (a good one!) and compressor, you also need a couple specialty sockets, large (1-1/8", 1-1/4", 1-3/8"?) plus spindle socket set. if you have this, or can get it, go for it.
the ball joint tool is also a u joint tool, and you will likely need it in hte future.
the first time i did it, i paid 95 bux JUST to get the joints pressed into hte knuckles!!!!!! that would have paid for the tool, and one of the ball joints (i was an idiot).
needless to say, i now have the tool, and the sockets.
good luck!
Old Nov 24, 2003 | 01:48 PM
77'F-150Mudder's Avatar
77'F-150Mudder
I second the Harbor Frieght idea. I bought their "cheap" kit ($35 I think) and was able to change the ball joints on my D44 with a couple different sockets as mentioed above. The thing practically paid for itself before I ever used it.
Oh yeah, make life MUCH easier on yourself and borrow some air and an impact. If you don't, you'll wish you did.
Old Nov 28, 2003 | 04:58 PM
bp_sigchi's Avatar
bp_sigchi
Thanks for all the advice guys.
So this ball joint c-clamp "press" is pretty useless on my truck. I'm srue there's multiple presses available, but out here in the middle of nowhere I don't have many options. I have the spindle off, finally, and managed to slam one of the joints out with a hammer.
The radius on the press from autozone is greater than the ball joint, so rather than putting pressure on the ball joint to press it out, it simply pushes up against the cast on the spindle.
Dark out and tired now.... 'think I'm going to try to find someone to press them out and in for cheap. If I take hte spindle off, hopefully it won't be too much $$.
Anyone else got any ideas??????????
You guys have been great! I apprciate all the help!!!!
Done had it up to here in Dryden
