Not starting after replacing intake gaskets
Old Jan 28, 2024 | 03:36 PM
dunecj2a's Avatar
dunecj2a
94 F350 460. Replaced the intake gaskets and now she wont start. We marked the distributor and rotor before removing. It went right back in with everything lined up. We have fuel pressure. Not sure if we should check something else before resetting the distributor. Seem weird that it would be off since it went right in with everything lined up on the marks
Old Jan 28, 2024 | 04:02 PM
rla2005's Avatar
rla2005
Put a timing light on cylinder #1, remove the SPOUT plug, then crank the engine over. If the light flashes verify the timing. If no flashing, troubleshoot no spark.
Old Jan 28, 2024 | 07:19 PM
dunecj2a's Avatar
dunecj2a
I have to do a timing cover gasket now. That started leaking after we fixed the intake manifold gaskets. I’m gonna have the timing cover off tomorrow.
Wolffman
32
Apr 1, 2014 01:21 PM
Smokinponcho73
Feb 5, 2013 07:04 AM
BossFan
Aug 13, 2011 04:35 PM
nairod
Escape & Escape Hybrid
Nov 22, 2008 04:42 PM
MRL123
Feb 19, 2007 11:32 PM
