2017 SuperCab F350
Old Jan 28, 2024 | 01:40 PM
TheWookie's Avatar
TheWookie
7th Gear
2017 SuperCab F350
New guy, need advice on possible first Ford.
I have a 6K lb travel trailer currently pulled by my modified ‘17 Tacoma. However, now that wifey and I are retiring we want to hit the road more often and longer trips for which I think my Taco wouldn’t be ideal.
So I have come across a ‘17 F350 Lariat 6.2l with 33k miles, 10800 package and not a scratch that I can see. It’s $39K at the local Ford dealer and Certified Blue). It’s always been a Nevada truck from the CARFAX so no road salt issues (I’m previously from CT so I’m used to vehicles rotting around me in real time). It’s also a super cab which will actually fit in my garage, a preference given all the vandalism, converter theft, breaking etc we all have to live with these days.
I’d love another diesel but given the extra costs and headaches I’m not sure I need it especially given the trailer size.
Any reason with the 2017’s I shouldn’t consider this truck for towing my trailer? Something I should examine before purchase?
Can anyone towing a similar sized 22’ travel trailer again their experience?
Thanks
Old Jan 28, 2024 | 01:47 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Nope, that is one of the most reliable trucks Ford ever made. Being a F350, you’ll also get the stronger 6R140 transmission. I just traded in the same truck (2018) after buying it new. Loved it.
Old Jan 28, 2024 | 01:59 PM
Joe T's Avatar
Joe T
Really reliable platform. Will be a little limited on going to oversized tires if it has 3.73 gears (would want the optional 4.30).
Old Jan 28, 2024 | 02:01 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
After having the Tacoma for as long as you did, you very likely won't like the ride of the F350 when it isn't hooked to the trailer.
A 6000 pound trailer would easily be towed by a F150, and get a much better ride, and should be able to find one for less money than the F350.
Old Jan 28, 2024 | 02:05 PM
TheWookie's Avatar
TheWookie
7th Gear
No need for oversize tires, got that on my supercharged taco for fun and play. This would strictly be for travel and trailering. Thx.
Old Jan 28, 2024 | 02:08 PM
TheWookie's Avatar
TheWookie
7th Gear
Appreciate the response. I’ve had late 90’s Cummins and V10 Ram 2500’s in the distant past so how bad can it be :-). Seriously though I expect the ride to be like my lifted Taco or even worse but I’m tired of living on the “edge” and the 350 would give room for a trailer upgrade in the future if desired.
Thanks again.
Old Jan 28, 2024 | 03:14 PM
mwheue's Avatar
mwheue
If upgrading trailers later, I wouldn't go bigger than 9 - 10k on the trailer if it's a 3:73 rear. Other than that I loved the 17 6.2 I had and traded in because I went to a 17k fifth wheel.
Old Jan 28, 2024 | 03:45 PM
TheWookie's Avatar
TheWookie
7th Gear
Thanks. It is 3.73. Were you trailering before trading in? If so, how heavy and what were you seeing for trailering mpg? Just curious.
Old Jan 28, 2024 | 03:53 PM
mwheue's Avatar
mwheue
I was towing a 32ft Keystone Cougar, it was around 9k loaded. 6.2 would Rev high in the mountains but maintain speed. As for mpg, 8-9 average. Mountains as low as 4 mpg and flat roads as high as 11 mpg.
Old Jan 28, 2024 | 08:51 PM
Joe T's Avatar
Joe T
I had that 6.2/3.73 combo with some 32.5” tires (little smaller than the 275/70/18) and the trick is to slightly pickup speed before inclines to where you would only let it shift down 1 gear by letting it decrease speed when going up; but also not digging into the throttle.
Also locking out 6th in really continuously hilly areas.
The trick is to keep it from downshifting 2 gears because that becomes uncomfortable if constantly doing that.
Also keeping it in 6th is night and day difference in fuel economy compared to 5th.
This method for me started coming into play around 7-10k lbs on long distances, never towed more than that on the highway.
Old Jan 29, 2024 | 05:05 PM
TheWookie's Avatar
TheWookie
7th Gear
So I went and checked out the F350. Excellent looking though not perfect as you can imagine, scratch here, scratch there. I have a question.
listen to this 6.2l. Is this tick normal or is that a lighter issue in the making? It has 33k miles.
iCloud link below.
Thanks.
https://share.icloud.com/photos/082p...FLneKJ3ukLtKdA
peachboy
Feb 15, 2021 10:42 AM
Drew Murphy
All Things Towing
15
Nov 29, 2020 10:38 PM
HAMMERDOWN103
Jan 24, 2013 05:13 AM
Fastbird
Feb 24, 2012 04:04 PM
