heat problem
Old Jan 28, 2024 | 08:35 AM
markfarris's Avatar
markfarris
1st Gear
Question heat problem
I have a 1998 Ford ranger with a 3.0 engine. I have intermittent heat. I have a new radiator,water pump,thermostat, and have flushed the engine and heater core. Sometimes the heater hoses are hot after 30 minutes of driving and sometimes they are cold. The heater valve seems to be working. Any ideas?
Old Jan 28, 2024 | 08:42 AM
charlie g's Avatar
charlie g
FTE Community Team
plugged heater core is my bet on a car or truck that old
Old Jan 28, 2024 | 10:49 AM
G2IC_Wraith's Avatar
G2IC_Wraith
As Charlie suggested, a heater core is possible.
It is also possible you need to “burp” the system.
You changed a bunch of components & sometimes it is difficult to get all the air out.
Most people don’t have the equipment to pressure bleed the system & just fill-n-chill.
If you don’t get all the air out you will have pockets that can prevent adequate flow.
Old Jan 29, 2024 | 04:49 AM
charlie g's Avatar
charlie g
FTE Community Team
HOW TRUE, in todays world it's best to fill using the vacuum systems out for this purpose such as https://www.harborfreight.com/automo...kit-64985.html all one needs is a air compressor ,and some time. follow the instructions, no air bound system
Mumbly Joe
Nov 17, 2022 08:10 PM
coonman111
Feb 1, 2022 07:26 PM
scottbernhard
1997 - 2003 F150
25
Jan 1, 2021 11:06 AM
shelby163
Mar 15, 2003 06:46 AM
Black_Bronco
1978 - 1996 Big Bronco
Oct 11, 2002 06:37 PM
