Towing with 4R75E
Old Jan 27, 2024 | 06:22 PM
tabijan's Avatar
tabijan
Towing with 4R75E
I read that a GM truck with a 4L60E should be kept out of overdrive when towing 2000 pounds or more to avoid burning the torque converter lockup clutches. Is the same true for a 4R75E? I monitor ATF temp on a ScanGauge and I haven’t seen 200*F, if that’s an indication of how hard the transmission is working. It drops to third or second on its own. I take it out of OD when it hunts or shifts frequently because of terrain or traffic. Otherwise I keep OD on.
I understand there’s a speed sensor that monitors slip but I don’t know if the logic is meant to prevent wear or throw in the towel when it’s worn.
Additionally, does this apply to carrying 2000 pounds in the van with no trailer? 12 aboard or 8 and a week of luggage is easily 2000 pounds.
Does the TC only lockup in OD or in any gear?
Sixto
07 E350 5.4 197K miles
Old Jan 28, 2024 | 07:08 PM
Nothing Special's Avatar
Nothing Special
I don't know about that trans in specific. But I think generally Ford OD automatics can tow in OD. If the clutch stays locked and you're not hunting, then keep it in OD. Otherwise downshift.
Likewise, most OD autos will lock up in D or OD. Likely not in any gears lower than that though.
ndtiger
All Things Towing
Apr 13, 2011 07:03 PM
A G
Oct 8, 2007 02:24 PM
hewy4444
All Things Towing
Feb 4, 2005 08:18 AM
slaymdr
Feb 4, 2005 12:22 AM
newtruck
Feb 26, 2002 11:29 PM
