6.8L 4.30 Capabilities
Old Jan 23, 2024 | 07:23 PM
Rwhjr's Avatar
Rwhjr
Work truck for a crew
6.8L engine
4.30 rear
towing a 16k equipment trailer
is the 6.8 that much weaker than the 7.3? Will it struggle to pull this trailer?
anybody having issues with these 6.8s? It’s not my first choice so I’m curious if I should avoid it if it’ll always be pulling a 16k trailer…..
Old Jan 23, 2024 | 07:26 PM
RandyinTN's Avatar
RandyinTN
6 or 10 speed trans?
Old Jan 23, 2024 | 07:28 PM
Rwhjr's Avatar
Rwhjr
a new 23 truck so it’s got the 10-speed
Old Jan 23, 2024 | 07:47 PM
Joe T's Avatar
Joe T
It should be fine per Ford’s ratings. If its a 250 or conventional pull trailer stay with the 245 base tires, will help with some mechanical advantage.
If so the Michelin MS2 should come on it and they are quite frankly one of the best tires I’ve ever had all around.
Old Jan 23, 2024 | 08:02 PM
TJP249's Avatar
TJP249
It will have the TorqShift-G 10 speed which is not the same that is in the 7.3 or diesels. It will be at the top end of it’s rated towing capacity. Will certainly do it, but it sounds like it will be towing that weight every day? If so I think I would pass. If it was towing occasionally then no big deal.
Old Jan 23, 2024 | 08:06 PM
Joe T's Avatar
Joe T
Is it 2wd or 4x4?
Old Jan 23, 2024 | 08:07 PM
Rwhjr's Avatar
Rwhjr
every day it will be pulling the trailer
and that’s the kind of stuff I was worried about. Completely didn’t even remember the transmission difference.
Old Jan 23, 2024 | 08:31 PM
twobelugas's Avatar
twobelugas
always towing 16k sounds like the job for a diesel, same surcharge as if you get a 7.3 in the XL trim.
Old Jan 23, 2024 | 09:34 PM
Just Chilling's Avatar
Just Chilling
How many miles a day? That’s only a midsized skid loader or a mini excavator.
Sounds like an ideal set up to keep employees from tearing stuff up.
Old Jan 23, 2024 | 10:23 PM
Rwhjr's Avatar
Rwhjr
150-200miles max per day…this thing isn’t going across the country and back…but it is used like a work truck
I think my gut has been telling me the 6.8 isn’t the right truck when 7.3 is available as a more solid option. The engine is built a little tougher and the transmission is stronger. That goes a long way for a tow vehicle in my opinion.
was hoping someone could change my mind since most of the XLs I’m finding have the 6.8 but it’s okay. I’d rather spend a little more and get a better tool for the job for the crew
Old Jan 23, 2024 | 10:57 PM
leadmic's Avatar
leadmic
If it were me I would at least do the 7.3L for the bigger transmission with that kind of weight.
Old Jan 23, 2024 | 11:55 PM
twobelugas's Avatar
twobelugas
Using a CCSB set up on ford's configurator, the 7.3 is standard in the XLT for 55K plus shipping, which comes with with 4x4. in XL trim, adding 7.3 requires STX and 4wd which bump it up to 58k plus shipping. that means the cheapest way to get a 7.3 is to go up to an XLT.
Old Jan 24, 2024 | 03:30 AM
sicdrummer27's Avatar
sicdrummer27
Go for a base XLT 7.3 instead of a XL 6.8. When I poke around with the configuration for CCLB 4x4 it's like a 2-3k price difference between trims. You get more features in the XLT and it comes standard with the 7.3L and beefier trans which is a large part of the price delta.
Old Jan 24, 2024 | 06:21 AM
WXboy's Avatar
WXboy
Engine wise nobody could tell a difference. I promise you nobody is going to feel a difference between 25ish horsepower. The ratings between 6.8 and 7.3 are so similar that I have often wondered why Ford even built the 6.8 to start with.
Transmission wise, yeah maybe this would be the concern. I believe the "G" version of the 10R trans is geared a little more toward fuel economy.
Old Jan 24, 2024 | 06:40 AM
jcb804's Avatar
jcb804
I used a 6.8L/3.73 as a rental for a few weeks towing my 15.4k dump trailer. Did the job adequately in my opinion and I ordered a 2024 6.8L/4.30 to replace the truck that caused me to rely on a rental.
