Ford E350 lights
Old Jan 22, 2024 | 10:33 PM
Bobby Detecting's Avatar
Bobby Detecting
Ford E350 lights
Hello everyone just today my 2008 Ford E350 parking front amber lights stay on and rear running loghts stay on when shut the van of and pull the key out and shut the pull switch all the way of. Headlights will shut off but not the amber lights and rear red running lights and the beebing noise stays on to push switch in but it is. Any help is appreciated thanks?
Old Jan 23, 2024 | 06:21 AM
blageurt's Avatar
blageurt
check fuses and relays could be a bad contact / corrosion
Old Jan 23, 2024 | 07:40 AM
tabijan's Avatar
tabijan
If the lights turn off when you unplug the switch, probably a bad switch.
Does your van have an automatic headlight feature?
Sixto
07 E350 5.4 197K miles
Old Jan 23, 2024 | 10:09 AM
Don Ridley's Avatar
Don Ridley
The main light switch is probably bad. Fuse F10 (20 amp) provides power.
Here is the electrical diagram.
https://charm.li/Ford%20Truck/2008/E...arking%20Lamp/
You could have some weird back feed if you have anything plugged into the trailer light socket.
Old Jan 24, 2024 | 05:04 AM
manicmechanic007's Avatar
manicmechanic007
+1 on replacing the headlight switch
The Terrible Blob
13
Feb 20, 2014 10:56 PM
1994F2507.3L
Oct 3, 2011 10:21 AM
Old Medic
15
Dec 3, 2010 12:59 PM
rooster22
Apr 27, 2010 06:09 AM
MontanaFord
Mar 14, 2004 02:15 AM
