Tune up question
You SHOULD NOT have to mess with the gap on OEM Motorcraft spark plugs. Matter of fact, you can damage the spark plug if you try! Otherwise changing the plugs is a simple process. Make sure you use compressed air to blow out any dust/debris from around the spark plug before removing it.
Motorcraft or Autolite plugs only. Going with so called performance plugs will only cause issues. Since don’t have a distributor and carb to fine tune, no sense in toying with gaps and heat ranges. Just set the plugs at the recommended gap.
If you aren’t having misfires, then don’t worry about replacing coils. If you should need to, Motorcraft only. The so called performance coils don’t work well on modern Ford engines. When you replace the plugs, use a torque wrench, the head is aluminum and you don’t want to strip the threads. For the same reason, turn the plugs in by hand as far as you can. If you need a wrench in the first 2 or three twists, then you are likely cross threaded. Back it out and try again.
Replace all of the coil boots with new ones. It’s cheap and easy to do while you’re there. Use a dab of dielectric grease on each boot and a tiny dab on each of the coil harness connectors.
You asked about this about a month ago!.
In that thread you had a 2.7 eco boost.
Unless a coil has been proven to be the cause of misfire, they are quite trouble free.
You may or may not replace the boots, your call, unless they show evidence of hardening, cracking, pin holes or other damage.. Otherwise you can't tell anything about the coil operation.
The grease is put just inside the boot tip just enough to lube and slide.. The grease does not do much for sealing. After about a thousand miles the grease goes firm from heat. The most important use of the grease is to help the boot tip find and slide down on the plug terminal because you can only feel what it does at time of carefully installing the coil in place.
The Grease is called Di-electric but is in not a dielectric at the high voltage the coil operates at.
The new plugs should be plated with Nickel and not need any further lube. It is possible that lubing can cause you to over tighten the plug from the reduced torque effort needed.
On plugs, if you have a 2.7, stay with the plug # or cross reference, that come out, for replacement. There is no HP in plugs, only the wrong ones
There are usually 3 levels of plugs listed. the only difference is their construction that affects their service life.
The higher costs usually reflect longer life from the metals used at the tip resisting spark erosion better over time that opens up the Gap more..
Otherwise there is no other benefit.
Don't make more of this than it is. Just use common sense.
Good luck.
Good luck.
Good luck.
2018 F 150 XL 3.3L V6 102313 miles. No problems. Book that came with truck says to change spark plugs at 100k miles. Asked dealer to change spark plugs. Work done Jan. 22, 2024.
Receipt says, removed and replaced spark plugs and intake manifold plenum gasket.
I don't know what this gasket is or why it was replaced.
Plugs $52.68
Gasket $24.83
Labor $202.50
Plugs $52.68
Gasket $24.83
Labor $202.50
I am trying to learn these newer trucks and how to do things correct as possible. This no distributor deal is odd for me. Just find it odd some boots don't show a spring included to others do. I was more surprised they don't keep the boots on the shelf for these years. Never hurts to ask . Thanks
