Rear ABS light
There is a single female connector on the wiring harness under LH dash, next to parking brake mechanism. It's hanging there with nothing plugged into it. You ground it with a jumper to a clean ground, make sure it's a good ground. When you switch on ignition, it will flash the light on the dash, giving you a code as to what's wrong. The info is on this site and all over the internet. The only item I never found info about regarding this is that if you have changed rear lights to LED, RABS will give a bad bulb code. In that case, put a Load Resistor between brake pedal switch lead and ground. Can't remember which color code on lead, but it's the one that goes to Turn Signal (multifunction switch)
I think I used 6ohms 25watt
Screw it to metal under there to help it dissipate heat.
The codes are a must or you will be chasing your tail for days.
Also, the connector on the Master Cylinder will give codes from flakey connections there
