Lost pushrod into engine
Old Jan 21, 2024 | 10:44 AM
5851a's Avatar
5851a
Pull engine and turn it upside down on a stand after you take precaution with the lifters. All the FE pushrods I've saw never broke, they bent.
Old Jan 21, 2024 | 11:12 AM
tbear853's Avatar
tbear853
I know, but I could imagine writing about one wrapping around the crank to make noise for the next twenty years.
Old Jan 21, 2024 | 12:15 PM
yardbird's Avatar
yardbird
There was an oil pump shaft in the pan of my old 390 when I built it years ago.
Old Jan 21, 2024 | 01:16 PM
Horsethief's Avatar
Horsethief
Found it yesterday, and turns out a pushrod can fall into the bottom end. It was in the forward most oil return hole wedged against the opposite lifter by its ball end. Seems that one false move would have sent it All the way down. Was able to use a very powerful 🧲 to grab it out. Now just have to clean up the mating surfaces and bolt her back together. Really wish I had an aluminum intake, as many times as I've taken this thing apart.. wouldn't be quite the pita if it was stock height, but the damn top or the engine bay is 5 ft up. Nothin to do, but just do it I guess. Thanks!
Old Jan 22, 2024 | 01:17 PM
5851a's Avatar
5851a
Back in the day a oil pump shaft was cheaper than a pan gasket. You had to make a choice.
Old Jan 22, 2024 | 01:36 PM
redroad's Avatar
redroad
If you haven't thought about it, Why not use your engine hoist to set the cast iron intake manifold on the motor.
Old Jan 23, 2024 | 09:40 AM
5851a's Avatar
5851a
My 67 car shop manual shows installing intake with hoist.
PagodaMomar
Jan 21, 2024 04:16 PM
Tinytune812
29
Feb 22, 2017 04:25 PM
LANEGRA99
Jan 18, 2008 11:26 PM
voodoosurfer
Apr 1, 2006 09:29 PM
Ford Tough
Jun 5, 2002 03:43 AM
