ASF-42C too small for head thread
Old Jan 19, 2024 | 02:49 PM
pogo619's Avatar
pogo619
Hey guys, have u seen this? I have a 1981 F100 with 302 auto.
I purchased a set of ASF-42C plugs but went to theead the first one and it almost fell in not catching any threads.
now, the previous owner added a 4bbl Edelbrock and a Holley Contender intake. I’m now wondering if they changed heads to 351?? The 351 uses ASF-52C. Would they be reasonably bigger? Any suggestions?
Jeff
Old Jan 19, 2024 | 05:09 PM
Franklin2's Avatar
Franklin2
All the older v8's used the larger plugs. More than likely the engine has been swapped out at some previous time.
I suggest you buy the same plug as you are taking out.
Old Jan 19, 2024 | 05:11 PM
pogo619's Avatar
pogo619
Figured it out!
Went to return the plugs to Oreilly’s. I’m friendly with a couple guys there so they did some digging and found the heads are 1969-1970 style with much bigger plug threads.
thanks, Jeff.
gman97005
May 20, 2013 11:48 AM
shephard199
Jan 14, 2010 09:20 PM
smoke n tires
Jan 12, 2009 07:58 AM
302 F-150
Dec 3, 2007 10:24 PM
tapnibot
1978 - 1996 Big Bronco
Dec 31, 2005 07:21 PM
