No Low Beams
Old Jan 17, 2024 | 12:18 AM
Alexis Garcia's Avatar
Alexis Garcia
No Low Beams
I’m having a problem where only my high beams work and my low beams don’t.
So when I turn on my light switch at night, the high beams turn on. But when I switch my multifunction switch to high beams, my headlights turn completely off. And my high beam symbol on my instrumental cluster doesn’t light up
So basically when I turn on my headlights, instead of it showing low beams it shows high beams. There’s no way at the moment to turn on my low beams
Would this be an instrumental cluster problem?
Old Jan 17, 2024 | 12:19 AM
Alexis Garcia
I’ve also replaced the multifunction switch seeing if that was the problem but it did not resolve issue
Old Jan 17, 2024 | 12:30 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Weird.
No other changes to the headlight/electrical system other than the multifunction switch?
Also what year truck. Dash had substantial changes.
Old Jan 17, 2024 | 04:16 AM
pvdiag's Avatar
pvdiag
If you changed a pigtail or something in the system recently, there is a possibility that the polarity of the wiring could be different. I just experienced this on a swap from aero to sealed beam headlights. Between the original wiring and conversion pigtail, somehow the "signals got crossed", so to speak. My prob presented as no high beams when switched on. The takeaway is that if you worked on something in the elec system, you could have inadvertently got things swapped around (maybe not even on the headlights themselves) and this is how it presents.
Old Jan 18, 2024 | 10:12 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Low beam usage these days is like turn signals on BMWs. The switch is there but why bother to use them?
Brendan Kuc
Mar 6, 2020 09:13 AM
Wvstream71
Aug 8, 2017 05:54 AM
Willfish4
2004 - 2008 F150
Jan 19, 2016 09:14 PM
mikeaj
Feb 24, 2007 01:35 PM
