Low Beam problem
Old Feb 22, 2007 | 01:27 PM
mikeaj's Avatar
mikeaj
Low Beam problem
I have a 2000 Ex. The low beams quit working but the High beams still work. I checked the bulbs and they look ok.
Any Ideas????
Old Feb 22, 2007 | 03:34 PM
NewXer's Avatar
NewXer
Do you mean that the low beams turn off when you turn on the high beams? if so, that is the way its designed.
Old Feb 23, 2007 | 07:58 AM
mikeaj's Avatar
mikeaj
Low beam problem
The low beams don't work at all.
Old Feb 24, 2007 | 01:35 PM
whjco's Avatar
whjco
Mike,
Most likely, you have a failed dimmer switch. Less likely would be a problem in a wiring connection in the low beam circuit.
