Sponsored by: Real Truck
Starter not starting
Old Jan 15, 2024 | 05:44 PM
Kintla's Avatar
Kintla
I have been getting a loud click and no crank when I try to start my 2001 f250 with the 5.4 l.
I jumped the starter from the positive lug on the starter to the s wire and it just clicks, does not start the engine. So not the ignition switch or clutch switch.
I pulled the starter out and bench tested it. It worked fine. It's only about 6 months old. Also put in a new solenoid on the inner fender to make sure it is good.
I put the starter back in and ran jumper cables from positive and negative on the battery, hooked up the jumper cables to the starter and jumped the S wire and still just a click from the starter. So, not bad ground or corroded cables.
Battery is good, new AGM yellow top, even pulled it out and put it on a trickle charger overnight. It tests good with my battery tester. I also hooked up to another rig with jumper cables just out of curiosity, still no start.
I think I basically ruled out everything that could cause a no start but still not getting the engine to turn over.
Any other ideas? What am I missing?
Old Jan 15, 2024 | 06:10 PM
Old and soft's Avatar
Old and soft
Engine/chassis to battery groind cable?
Old Jan 15, 2024 | 06:32 PM
Kintla's Avatar
Kintla
I think I ruled that out when I ran jumper cables from battery directly to the starter when in the truck, both positive and negative. Positive to the large lug on the starter and negative to the starter body.
I'm missing some failure point, just not sure what. I'm wondering if the starter works when bench testing but doesn't have the cojones to actually crank the engine. It's cold here, high today was below zero, low was pushing negative 30.
Old Jan 15, 2024 | 08:42 PM
projectSHO89's Avatar
projectSHO89
Pull the serpentine belt off and check the accessories for anything binding. A failed A/C clutch pulley is not uncommon and it will "lock up" the engine and prevent the starter from cranking.
Old Jan 15, 2024 | 08:53 PM
Kintla's Avatar
Kintla
I tried to compression start it, but it was on snow with poor grip and couldn't get it to turn over.
I'll check accessories, crossed my mind that the engine could be locked up. Ran fine when I shut it off last time. I've had this click no start before, though it would usually fire up.
I'm stumped.
Old Jan 15, 2024 | 10:24 PM
Kintla's Avatar
Kintla
Pulled serpentine and everything moved freely.
Was hoping that was going to turn something up.
Will turn the engine over by hand tomorrow and see what it does. Might throw a new starter at it I guess tomorrow if the engine turns over fine. No idea why it would bench fine but not work in the truck.
This is my plow truck and we're due for 12" to 24" in the next few days. Got to get it to fire up.
Old Jan 16, 2024 | 09:16 AM
projectSHO89
Try cranking with the belt still removed and verify the condition still exists.
Could easily be a corrode connection or cable (internal to insulation). Your jumper cable test may not have been sufficient to properly test.
Use your meter to check the voltage at both the large and small terminals on the starter while trying to crank to make sure you're not dropping your supply voltage.
Old Jan 16, 2024 | 02:30 PM
Kintla's Avatar
Kintla
Really appreciate your suggestions, I tried cranking with no belt, same problem.
I took apart the cable end that hooks to the battery and soldered on a new end, attached it to a new side post on the battery and tried to start it, it just clicked again, then hooked a jumper cable from my other truck to that lead and it fired up, so you were right, running a jumper cable from the battery to the starter in the truck was not helpful info. Seems like the cable is not carrying juice like it should and that coupled with a cold battery was the problem..
Probably need to replace the cables, might be corroded under the insulation (no real corrosion visible at cable ends).
Thanks again.
Old Jan 16, 2024 | 02:39 PM
projectSHO89
Just make the voltage checks. Ten minutes of work. Avoids all this drama.
Old Jan 16, 2024 | 02:55 PM
Kintla's Avatar
Kintla
I did check voltage, got 12v at starter, but kind of hard to check the voltage drop when cranking by yourself. That was the idea behind jumper cables to the starter to take cables out of the equation. Apparently didn't work.
Old Jan 16, 2024 | 03:28 PM
projectSHO89
You have to check it under load or it doesn't much count.
Three words: Remote starter switch.
Old Jan 16, 2024 | 03:30 PM
projectSHO89
Old Jan 16, 2024 | 08:43 PM
Kintla's Avatar
Kintla
​​​​​That would've worked better than the jumper cables.
Got one on order, thanks buddy.
Old Jan 17, 2024 | 08:04 AM
projectSHO89
You can connect it between the battery's positive post and the small terminal on the starter relay then drop it down so you can activate it while under the truck with your meter connected between ground and the two circuits to be tested. Also test between the battery's negative post and the starter's case so you can test the ground circuit's integrity. You'd be looking for little or no voltage to be measured across the ground circuit under load.
If the voltages don't drop too much, then it's likely a failed starter.
Old Jan 20, 2024 | 01:53 AM
EDC8008's Avatar
EDC8008
And yes even "FRESH REBUILDS" have proven to be bad from time to time. Also NONOEM can be defective when new.
ford76460
20
May 12, 2017 08:37 PM
LSJUNIPER
Nov 22, 2010 11:39 AM
godawgz99
16
May 25, 2008 07:02 PM
dracip
Jan 28, 2008 06:43 PM
T-bud
Feb 20, 2007 01:18 AM
