Gasping for air
Old Jan 15, 2024 | 07:47 AM
Felonious Traveler's Avatar
Felonious Traveler
Gasping for air
What is causing this horrible gasping noise when I shut off my RV (please see video). Vehicle is a 94 F53 motorhome, 7.5L, 50K miles, with headers. Belts and tensioner are new.
https://youtube.com/shorts/M75TBfQUpzw?si=A5gXbpEq8A3JVgLf
Old Jan 15, 2024 | 05:13 PM
'89F2urd's Avatar
'89F2urd
Remove all of your vac lines from the intake and plug them, at the intake, and see if it still does it.
What's that brand new pump on the front drivers side?
Old Jan 15, 2024 | 07:15 PM
Felonious Traveler
Thanks for the reply, I'll give that a try. The "pump" is a new air conditioner. The smog pump took a dump years ago and has been disconnected (pulley removed) I wonder if it might be part of that plumbing, like a vacuum canister maybe.
Old Jan 15, 2024 | 08:37 PM
'89F2urd's Avatar
'89F2urd
I suspect that it's your brake booster making the noise, and the simple disconnecting of the vac lines will confirm that, or rule it out. Could also be that new ac compressor, to which I'd say - start it up, and then immediately shut it off. Do that a few times, if the noise is there consistently under those quick start and shutoff conditions, then remove the serpentine belt and see if it happens. If not, then its the ac compressor.
Old Jan 16, 2024 | 07:39 AM
Felonious Traveler
Ok, excellent ideas. I'll explore that and let you know. Thanks.
Old Jan 16, 2024 | 07:54 AM
Felonious Traveler
Here's a longer video showing a stop and start of the drama unfolding in the engine bay of my RV.
Old Jan 16, 2024 | 08:51 AM
manicmechanic007's Avatar
manicmechanic007
Not exactly sure what causes that but they sure all do it
My 351 1994 van does it real bad if you consider that bad
I consider it normal and have never thought what might be causing it
I doubt it is the booster because they hold their vacuum when you shut the engine off
Those intake pipes are a kind of resonator
The sudden airflow loss of turning off the engine may cause the gasp noise through that resonator?
Maybe the IAC port is making the noise?
Old Jan 16, 2024 | 05:13 PM
torq'ta 5 8's Avatar
torq'ta 5 8
My fox body did that, when I bypass smog pump, at the track, then stopped when I put belt back, to drive home.
cjben
Jan 16, 2024 01:11 PM
82_F100_300Six
General Automotive Discussion
Mar 19, 2017 08:14 PM
Raider50
Feb 22, 2008 05:35 PM
Club Wagon
May 6, 2007 12:16 PM
JCooke
Jun 11, 2005 06:21 PM
