Sponsored by: Real Truck
Plug and play programmers??
Old Jan 12, 2024 | 06:09 AM
Painful powerstroke's Avatar
Painful powerstroke
4wd Low
Looking into cheap programmer options found this on Google, are they any good? I have a 2000 f250 7.3L, 6 speed manual transmission
Old Jan 12, 2024 | 11:45 AM
Pickupmanx2's Avatar
Pickupmanx2
I have had good luck with Hypertech programmers in my fleet, had one in my '02 Excursion, one in my '01 F350 and I currently have one in my '02 F350, all 7.3's, I personally would stick to known brands, not a knock-off.
Old Jan 13, 2024 | 01:14 AM
INFRNL's Avatar
INFRNL
Do you have gauges? I wouldn't do anything without an EGT gauge at the minimum. I only recommend/ use a PHP Hydra, but that's just me
and i hope you are not looking at one because of that false 5mpg gain BS. You will most likely not gain anything but a bit of extra power. I good chip like a Hydra can definitely wake these trucks up.
Old Jan 13, 2024 | 03:51 PM
'89F2urd's Avatar
'89F2urd
I would stick with the cheap 5 position tuners that have been around for decades, if cheap was what I was after.
Old Jan 13, 2024 | 07:10 PM
Painful powerstroke
4wd Low
Right on right on I'll check into those thanks
Old Jan 13, 2024 | 07:38 PM
00t444e's Avatar
00t444e
No, get a Hydra chip.
Old Jan 14, 2024 | 07:17 AM
Old and soft's Avatar
Old and soft
Buy once, cry once. Hydra can also be programmed with a no start setting. Set it, take the controller with you. Now the criminal needs a controller, or a tow truck.
Old Jan 14, 2024 | 11:42 AM
Painful powerstroke
4wd Low
I'm really just looking at what's out there and still have a bit of a ways to go before the programmer stage... as I've posted in other threads, the truck was sitting for nearly 5 years, and had rat issues along with typical issues when dealing with 308k miles on a truck. Guages are probably the next step. Considering a duely conversion eventually... lots to do, and want to get the most bang for my buck with out dropping 100k into a 25 year old truck
Old Jan 14, 2024 | 02:10 PM
'89F2urd's Avatar
'89F2urd
you'd be fine with one of the **** chips on a low setting w/o gauges, just to get the throttle response and make it feel like not such a turd.
Old Jan 15, 2024 | 01:27 AM
INFRNL's Avatar
INFRNL
This is the worst advise to someone, especially if they are new to this.
A stock truck can have EGT issues without a chip. a chip with any tune will just make it worse.
Gauges also help aid in troubleshooting or knowing when something isn't right.
The same could be said about an all out tune. I know how my truck works and I can drive without gauges, but I don't think that's what you tell a newbie.
He's on the right track. Get his truck up to par, add at least an EGT, and then think about extra power. He also needs to make sure his up pipes and all piping is leak free.
He also if not aware, needs to know that he should maintain 1250 EGT's or lower unless he wants to risk his engine. Many just think you can throw a chip/ tuner in and race around like a car...doesn't exactly work like that.
We also don't know his location or use. If he's anywhere near high elevation things aren't so easy, especially if doing any towing and if he has a boost leak that he will not be aware of.
but sure, in the perfect world a low power tune shouldn't be an issue w/o gauges. I won't put a chip in anyones vehicle without a way to monitor EGT's.
My best friend thought the same thing...oh it's fine I know how to drive my truck....I don't need gauges. He finally got a gauge and realized how everything absolutely wasn't fine and how quickly EGT's can get out of control. he only uses a low power tune too.
Old Jan 15, 2024 | 04:45 PM
'89F2urd's Avatar
'89F2urd
Yea, I won't argue with the principled stance, so you're right.....but, it's so very incredibly unlikely that a stock injected 7.3 gets destroyed by a chip that, well, it'd have to be used by someone incredibly ignorant and negligent to damage anything. Temp risk would be accompanied with huge amounts of black smoke, indicating a boost failure of some kind.
Aaron_b32
Dec 2, 2023 03:58 PM
FourthFitz
Feb 21, 2020 02:02 PM
jaywhy
Jun 9, 2014 08:50 PM
porman924
Jan 17, 2011 01:02 PM
