EFI starting issue
Old Jan 11, 2024 | 08:26 AM
Angrybarncat's Avatar
Angrybarncat
4th Gear
EFI starting issue
Hello,
I have a 88 5.0 efi that stalled on me and died while back and wouldn’t start and had to pull it home. It goes through spells where it spins over really fast (kinda like the starter isn’t engaging, even though it is) and switches back and fourth where it turns over like normal. Every once in awhile it will start but doesn’t run very good. It does have spark and tested the fuel pressure at the rail, fuel pressure jumps up to where it’s supposed to be but does bleed back off quick (does the same thing tho when it starts and does not start). Only active code was a egr one. I did a tune up few months before this happen (plugs, wires, cap, rotor, coil). Any help would be greatly appreciated! My diagnosing skills are limited and im loosing hope, not sure where to go from here
Old Jan 11, 2024 | 08:41 AM
jas88's Avatar
jas88
Will it run on starting fluid?
Old Jan 11, 2024 | 08:46 AM
Angrybarncat
4th Gear
nope, doesn’t seem to make a difference
Old Jan 11, 2024 | 09:49 AM
jwitty's Avatar
jwitty
The part where you say it sometimes turns over really fast, other times is normal and runs poorly, makes me think you have some valvetrain issue
Old Jan 11, 2024 | 09:59 AM
Angrybarncat
4th Gear
Do you think a compression check would be helpful for looking into that?
Old Jan 11, 2024 | 10:03 AM
jwitty's Avatar
jwitty
yes. Especially if you can recreate the 2 modes and find if there are differences.
you could also try leak down after compression check.
Old Jan 12, 2024 | 11:48 PM
Angrybarncat
4th Gear
ok thank you, I will check that next
HM02
Nov 5, 2023 08:28 PM
ford4x4302
May 3, 2017 07:24 AM
Ronnie Locke
Apr 24, 2013 08:48 PM
ford302stang
Dec 2, 2006 08:07 PM
baldy9
Oct 25, 2001 08:29 AM
