New wheel bearings,rotors and vibration
2001 Ford excursion 7.3 2WD. Just replaced brakes, rotors, bearings/seals on the front end. I used Detroit Axle rotors (they came with the races already pressed in) and brakes, timken bearings and seals. All felt good until I took it out it speeds 50+ and now I have a new slight vibration in the steering wheel (not when braking, just cruising) I've double checked the torque settings on the spindle nut... I may crank them down tight again to make sure they're fully set, back then off, and then retorque. Other than that..any thoughts/ideas. Is there something else I should check. End links, ball joints, and bushings have all been replaced in the last year and look in good shape.
kjbronco
02-19-2009 08:46 PM
lilbilli0naire
01-10-2009 03:48 PM
tkd
08-08-2007 04:43 PM
